PVC system problem or bigger?
Is there more to the PCV system than just the passenger side fresh air tube connected to the TB on the pass side top most tube connector and the PCV valve on the drivers side ( 97 LT1 ) connected to under the TB?
I have a leak on the pass side and its either coming from the valve cover itself ( just put new gaskets on, everything looked good ), the filler tube or worse oil coming up from the dipstick. I had this leak before the new valve cover gaskets just not as bad. I added an o-ring to the base of the filler tube and screwed it back on but did not help. so I am thinking it must be coming from the dipstick tube. If that is the case the PVC system is not working correct?
Last I checked ( month ago or so ) the PCV valve was ok.
Is this a sure sign of a rebuild needed? Or is it a take the intake off and check? or is the TB pushing / allowing air from the intake to be shoved into the pass side head?
I would think the new gasket is not properly installed. The rubber gaskets like to pop off the corners when you go to install them. I like to dab all corners with rtv before re installing.
Slip the larger PCV system hose (runs to the pass valve cover) off of the throttle body. With the motor running, see if air is blowing out the hose. If you feel any significant amount of air blowing out the hose, you likely have blow-by and thats indicative of needing a rebuild. That can also casue oil leaks.
Thanks..
The more I read the more I think it will need a rebuild. I will definitely see if that larger pipe has any significant airflow. But I am thinking I need to prep myself for the cost of a rebuild...
Good news for me ( I hope LOL )
I took that tube off the TB and started the car up and did not feel much if any air coming from the tube. I also pulled the PCV valve while running and it was whistling with the suction that was being created. So that is good news.
I also opened the filler tube and did not see any puffs of smoke ( maybe need to check after its warm )
So now I am thinking the valve cover is warped. Any sure fire ways to KNOW that it is sealed correctly? bead of RTV on the head, let dry and put cover on maybe?
