lack of steel for lt1
Old 02-22-2012, 07:25 PM
nazztman4739's Avatar
Default lack of steel for lt1
i have been searching for a week straight all over the internet i can not find a stock stroke cast steel lt1 crank and i was told if i use a late model 350 1 pc seal i have to change the flywheel and balancer to the older style can someone help???
Old 02-22-2012, 07:35 PM
duh
duh's Avatar
the late model 350 flexplate is the same as the LT1. I don't recall if the balancer bolt is the same, but IIRC the threads are the same at which point the balancer would bolt up just fine. If I'm not mistaken the crank from any 87+ SBC 1pc rear main will work just fine in an ltx engine. I may be wrong tho.
Old 02-22-2012, 07:37 PM
Low N Slow's Avatar
The LT1 is a late model 350 1 piece seal.
Old 02-22-2012, 08:02 PM
RamAir95TA's Avatar
With the amount of people upgrading stock cranks to strokers you shouldn't have a problem finding a good used crank.
Old 02-22-2012, 08:15 PM
97Z28SS's Avatar
I have a good stock one if you're interested.
Old 02-22-2012, 08:16 PM
zraffz's Avatar
Check out rockauto. Think they are like $150.
Old 02-22-2012, 09:53 PM
So i can take a crank from a 89 350 crank and install it in a lt1
Old 02-22-2012, 09:55 PM
If i can find a block that has already been clearanced for a stroker im ginna stroke it
Old 02-22-2012, 09:59 PM
RamAir95TA's Avatar
Um. Different cranks require different clearancing, usually. Are you sure you know what you're doing?
Old 02-22-2012, 10:09 PM
Yes i know but if i can find a block that was slready clearanced i can get fairly cheap i will stroke it if not a 350 is a 350 even if it is a lt1 code
Old 02-22-2012, 10:10 PM
My issue is balancing questions
Old 02-22-2012, 10:13 PM
RamAir95TA's Avatar
I admit I no longer have any idea what you're talking about.
Old 02-22-2012, 10:45 PM
05HD's Avatar
Originally Posted by ramair95ta
i admit i no longer have any idea what you're talking about.
lmfao!
Old 02-23-2012, 09:18 AM
3DFORMULA's Avatar
Not just any 350 is a LT1, if that is what you are asking. So if you are going to reuse your heads, the 350 you are looking at MUST be LT1, not vortec 350
Old 02-24-2012, 01:22 PM
WS Sick's Avatar
The crank though, as long as it's a 1 peice RMS, will work, flexplate, balancer bolt, clearance etc.
Old 02-24-2012, 03:22 PM
jaycenk's Avatar
Only thing I question is the snout length. but other then that it needs to be balanced like the LT1 which I know most 350's are not or it needs to be neutrally balanced which you typically give a machine shop the pistons, pins rods and bolts anyway so have them make sure the journals are right for the rods and you have to use a neutral balance flex/flywheel and the stock damper is neutrally balanced. Long story find a stock Nodular Iron crank from any LT1 LT4 except the mini LT1.
Old 02-24-2012, 03:25 PM
Prorac1's Avatar
Its not that hard to clearance an LT1 block as long as you get the RIGHT rods. FWIW, an oliver billet thats contoured around the big end fits REAL well. Eric L
Quick Reply: lack of steel for lt1
