where/is there a wire connector on the purple wire from the starter on LT1?
Old 08-22-2012, 04:32 PM
BadBirdie's Avatar
Default where/is there a wire connector on the purple wire from the starter on LT1?
In this pic of an ls1 its circled but on my lt1 its not anywhere in that area. I opened up the looms in that area too. Where is it or do lt1s not have it?
Old 08-22-2012, 04:36 PM
TwoFast4Lv's Avatar
OK Now that you pic is up..No not on a LT1
Old 08-22-2012, 04:53 PM
BadBirdie's Avatar
ok heres what im trying to do - i probably fried my BCM but i want to make sure before i buy a new one. heres the other thread i made and was trying to do what ROCNDAV suggested. is there anyway to test this on a lt1 without this connector?
https://ls1tech.com/forums/pcm-diagn...r-bcm-fix.html
appreciate the help
Old 08-22-2012, 05:10 PM
TwoFast4Lv's Avatar
Well. You do not realy have a "BCM" to start with. Some one is just naming it that. Show me a pic of the boxes.
Am I sure?
Yup after 8 hours in the GM manuals last sunday I am pretty sure it is not called a "BCM"
Old 08-22-2012, 05:49 PM
BadBirdie's Avatar
Old 08-22-2012, 06:09 PM
TwoFast4Lv's Avatar
Anf that came out of YOUR LT1?
I very well could be wrong for the 97 year let me look.
Old 08-22-2012, 06:26 PM
TwoFast4Lv's Avatar
Ok. It is not a BCM in the true sence of a BCM. They combined three modules(RAPS, VATS, and Keyless entry) into one and called it the IBCM.
For that yes I was wrong. Again it realy does not do the job of a normal BCM
Old 08-22-2012, 06:45 PM
BadBirdie's Avatar
ok its an IBCM. Is there anyway to test to make sure its the IBCM thats fried and not a relay or something i dont know about? Just want to make sure i dont go out and spend about $300 on a new IBCM if i dont have to
Old 08-22-2012, 06:56 PM
TwoFast4Lv's Avatar
Pull the Theft detrent relay and jump the yellow wire to the Purple wire and see if it turns over. It may turn over and start for a little bit and then die. there is no other connector in that run until the connector under the Pass kick panel
Old 08-22-2012, 07:25 PM
BadBirdie's Avatar
Where is the theft deterrent relay? Could that be what i hear clicking when i try to start it?
Old 08-22-2012, 09:20 PM
shbox's Avatar
It is to the right of the glove box.
Quick Reply: where/is there a wire connector on the purple wire from the starter on LT1?
