tpi head vs lt1 head
Old 10-09-2012, 06:23 PM
93z28de's Avatar
Default tpi head vs lt1 head
hay there how are you all to night my ? is how can i tell a l98 corvette head from a lt1 head bye looking at it i have a casting # and i think i may have jumped the gun its 10207843 i cant tell if its a 8 or 6 any help is a big thanks
Old 10-09-2012, 06:39 PM
ascastil's Avatar
I believe its 7643, which is the desireable lt1 casting for porting.
Old 10-09-2012, 06:41 PM
94stripperZ's Avatar
LT1 heads wont have the large coolant crossovers next to the intake ports on either end
Old 10-09-2012, 07:18 PM
93z28de's Avatar
well i guess i need to take them back lol
Old 10-09-2012, 08:41 PM
96capricemgr's Avatar
Need to take them back because they do have the cooling ports? The casting numbers can be deceiving sometimes just due to casting quality. 6-8-3 can all easily be mistaken for eachother.
Old 10-10-2012, 04:05 PM
93z28de's Avatar
Default yep
yes no cooling ports trying to do a gen one motor
Old 10-10-2012, 04:07 PM
whytryz28's Avatar
So you're doing a gen I engine but you have LT1 heads?
Old 10-10-2012, 04:23 PM
You might consider adapting the heads? Is the gen 1 going to be using say the TPI injection system? If so LT1 heads and intake are a pretty meaningful upgrade. They do need to be drilled for the coolant crossovers and distributor.
Old 10-10-2012, 08:27 PM
93z28de's Avatar
well i got good news and bad new's good news looks like some one set them up for a gen1 block bad news they were for my dad so now im eating 200 some bucks. and maybe getting a mixed up dream motor lol i all ways liked the tpi but loved the lt1 top end so whats the bast thing to do make a lt1.5 as im going to call it. gen one block with the lt1 heads and intake now what do i do for ecu or dizzy?
Old 10-10-2012, 08:36 PM
Couple options. I believe there is a Vortec rearmount distributor that can work with the LT1 pcm or the TPI could be made to work especially if you already like that system.
Old 10-10-2012, 08:42 PM
RamAir95TA's Avatar
Makes absolutely zero sense to go through the hassle of putting LT1 heads on a SBC block especially when the selection of heads for SBC outnumbers the LT1 20 to 1 and at a MUCH cheaper cost.
Old 10-10-2012, 08:53 PM
93z28de's Avatar
finding l98 heads or something around lower Delaware is a pan and i do not like iron heads because i will run boost and iron head's are only good for boat anchors now days,just how i feel
Old 10-10-2012, 09:58 PM
whytryz28's Avatar
A set of LT1 heads are cheaper than a set of aluminum sbc heads since they will most likely be aftermarket.
Old 10-10-2012, 11:16 PM
This is the key, he bought them at core head price already modded.
Old 10-11-2012, 02:25 PM
93z28de's Avatar
96capricemgr this is true and even if they had not been done i know how to do it all my self
Old 10-12-2012, 08:17 AM
93z28de's Avatar
so how can i find some post were other ppl have done this swap
Quick Reply: tpi head vs lt1 head
