Knock retard
Knock retard
Was screwing with my car today and found something interesting. It has Pacesetter long tube headers and it registers knocks. The timing at 3500 RPM is at 41 degrees. (Mail order tune) I'm thinking the guy tried to offset the knock retard with more timing. Is that a reasonable assumption? I'm getting knocks at idle so I doubt the timing is really making it knock.
What I'd like to do is de-sense or kill the knock sensor/count and lower the timing to something more reasonable. Just sitting in the garage it retarded 3 degrees after a while. Not enough but who knows what happens when it does a burn out.
Also found a intermittent left side O2 sensor. Probably a wire melted to the header or a loose connection.
I wasted half the day trying to get TunePro RT to see the interface. Didn't happen and even if it did it will take me a few days to figure out Winflash. So I'm hunting for recommendations on a EASY program to do this. My laptop has Vista and Microsoft built the worst security anyone could possibly dream up. My old laptop had XP in it but my OT race car vibrated it off a folding chair and killed it. BTW: FreeScan and Datamaster both work, but TunePro RT just can't see the interface?
Any ideas?
Al 95 Z28 LT4 knock module, almost stock engine with a Lunati cam. Got a 12.1 out of it but now it wants to run 12.3 to 12.4. My 60 foots suck, but that a problem for a different week.
Any ideas?
I'll try Tunercats, if I can get it to work. Things are so much easier with a regular distributor and a Holley carb
Is this the correct forum for this question?
Al 95 Z28
Well color me stumped. Screwed around with TunePro RT for another hour and a half. No way can I get it to connect with the car. The "test for valid interface using settings" test says it's working. Free Scan reads perfectly, all I get in TunePro is it can't find the hardware. One thing that's different, Free Scan says the interface is on port 5, TunePro says it's on 3. But I'm sure that's a red herring.
I did everything in the tutorial. Everything works as stated except it can't see the PCM??
One other thing, in the EE.xdf file, the spark tables are not at all like the screen shot in the tutorial. The numbers are all over the place. I downloaded the file three times just to see if I screwed something up. All exactly the same.
Al 95 Z28
Al 95 Z28
change the port on tunerpro, to 5, and always use that port unless you like changing the config around every time you use a different usb plug in.
for some more tunerpro help and files to be found...http://www.gearhead-efi.com/Fuel-Injection/forum.php
there's a lot of tunerpro info there.
http://www.monodax.com/forums/forums.php
for tunercats... to get that to work... the install file has to be run as windows XP compatability mode... it's on their website I believe.
for the timing issue... try this tune I attached out.
Thanks for the help. I'm getting nowhere, going to attack the O2 sensor problem.
Al 95 Z28, TH400, Dana 60S, stock engine with a cam and roller rockers.
not sure why the computer isn't seeing the port correctly. That skill has left me many years ago.
you aren't using all three programs or any combination at the same time are you? might be conflicts if they tried to all access the same data at once.
Al 95 Z28
