egr delete running rich.
I recently deleted my egr solenoid. will this cause the car to run rich?? i also took off all the air pump stuff and left the pump plugged in but looped the air hose back into its self.. and added headers and throttle body. i left the little solenoid on the driver side plugged in also. im waiting to get a retune but im wondering if doing all the things i listed above would make it run rich?
I listed all my mods on a previous post and you told me they were all missmatched.. but anyway. 383 internally balanced eagle rods and crank srp pistons.11.3.1 cpr..has stock lt1 heads with new valve job 1.6.1 comp cam rocks cromemolly pushrods. studs and guide plates. twin 58mm lingenfelter 44lb injectors . pacesetter LT. cc503 cam, i cant remember what spring.. but anyway. the car was dyno tuned with all those mods except the headers and throttle body...So all i changed was TB, headers and egr delete
9-Second Club
Was it tuned for those bigger-than-you-need injectors?
You may as well pull the AIR pump off. And, no. Deleting the EGR won't make your car run rich. I would make sure the coolant temp sensor is plugged in, and that the connector is in good condition. If you don't know, that is the little 2 wire sensor on the water pump, driver's side.
Hope this helps.
Hope this helps.
yes the car was tuned for the injectors. and yes it ran fine before i deleted the egr and air pump tubing,headers and throttle body..it could be a number of things at this point. i checked the water temp sensor wire and its good no ses lights either
I left something out. The throttle body I put on it was for a tpi so I bought the tps pigtail and wired it in. I was having trouble because they put the wires in the connector wrong to when I gave it gas the volts would go down instead of up. I think I got that fixed. I set the volts for .7v at idle and it goes to 4.8v at wot. Maybe this is the problem
