Which MAP Sensor for '93 24x LT1?
Old 05-08-2013, 11:22 PM
JamesZ28's Avatar
Default Which MAP Sensor for '93 24x LT1?
Ok so I recently installed the 24x conversion on my '93 LT1 along with some other mods. A question I ran into early on was what MAP sensor would I be using. When my harness was being built they asked what I'd want and I believe I told them a 3 bar (Does this make a difference in what plug they'd put on the harness or something?). Anyway I gave them a call and they told me I'd be able to use my current sensor since "they're all the same." Anyway that's where my main question comes in for everyone here. We tried hooking up the plug in my new harness to my '93 map sensor and the plug is slightly different. Very close to being the same, but not quite. Does anyone here know what sensor I need? LS1? I noticed the part number on all '93-'97 LT1 sensors is the same so I'm just kind of lost here. Any help would be greatly appreciated! Thank you!
Old 05-08-2013, 11:31 PM
BOOSTED AFR's Avatar
You will have to find a 3 bar MAP sensor. Factory LT1 MAP sensors are only 1 bar. Supercharged 3800s are 2 bar MAP sensors and I'm not real sure what came factory equipped with a 3 bar MAP but I think it was the Turbo Trans Am in 1989. Regardless each MAP sensor has a slightly different connector.
Are you planning on supercharging your car?
Edit: I think the 2 and 3 bar sensors have the same connector layout
Old 05-08-2013, 11:54 PM
JamesZ28's Avatar
Turbocharging. So I'm assuming I'll have to get in contact with eficonnection again to see exactly what map sensor connector I've got on my new harness?
Old 05-09-2013, 12:05 AM
Contact EFIConnection or look on google images at the color of the connectors for each different bar value.
1 bar is typically a green connector
2/3 bar is typically a white, black, or orange connector
Below is a picture of the 2/3 bar connector
Old 05-09-2013, 12:07 AM
JamesZ28's Avatar
Contact EFI connection or look on google images at the color of the connectors for each different bar value.
Thanks for the info! I believe my current map sensor has a green color on it while the new connector on my harness has an orange color.
Old 05-09-2013, 12:11 AM
A 2 or 3 bar MAP should work for you then. I guess it would come down to the amount of boost you want to run.
below 14-15 psi = 2 bar
above 14-15 psi = 3 bar
Old 05-09-2013, 12:16 AM
JamesZ28's Avatar
The plan is to start around 6-8psi on pump gas then upgrade the fuel system, e85, and shoot for around 18-20psi. So I was planning on just using a 3 bar right from the start. Thanks again for all the help though!
Old 05-09-2013, 12:20 AM
Happy horsepower hunting brother!
Glad to help
Old 05-09-2013, 04:23 AM
S10Wildside's Avatar
This is a difficult harness build requirement because at 6-8 psi, you will use a 1-bar MAP (green harness connector). As soon as you go 15 psi, the MAP sensor must be replaced (2-bar) and the orange harness connector is required. So, you've received the "correct" harness connector, but also the "wrong" harness connector.
Another example:
Some customers have requested a 4L60-E harness connection with future plans of a 4L80-E. They are pinned a little differently and require different harness lengths. When building a new harness, it's one or the other.
Old 05-09-2013, 09:30 AM
blown383z28's Avatar
so can we put a 3 bar on it now with 5-8 psi? or do we have to run a 1 bar for this summer? can i just put his green conector on his new harrness for this summer?
or can we just buy this 3 bar and call it good?
this on is the AC Delco (new)** 213-1562
http://www.oreillyauto.com/site/c/de...yword=213-1562
this one is the AC Delco (old)* 213-101
http://www.oreillyauto.com/site/c/de...yword=16040749
Old 05-09-2013, 10:19 AM
1 bar map = 1 bar vacuum - 0 bar boost (-14.7 psi - 0 psi)
2 bar map = 1 bar vacuum - 1 bar boost (-14.7 psi - +14.7 psi)
3 bar map = 1 bar vacuum - 2 bar boost (-14.7 psi - +29.4 psi)
With any boost a 2 bar MAP is required for boost referenced tuning. Beyond ~14.7 psi boost a 3 bar MAP is required.
Additionally, properly tuned there is nothing wrong with running a 2 bar MAP with no boost(at least until you can get to that point). The MAP referenced tables will just have reduced resolution.
Old 05-09-2013, 10:37 AM
JamesZ28's Avatar
Originally Posted by blown383z28
this one is the AC Delco (new)** 213-1562
Does anyone have any input on these?
Old 05-09-2013, 10:48 AM
Best I can tell these are both 3 bar just different manufacturers.
One sensor is a Borg Warner and one is Delphi.
Quick Reply: Which MAP Sensor for '93 24x LT1?
