Well, How'd my STREET car do at the track?
for starters this was my second time ever at the drag strip. The first time was roughly 3 years ago. I got to make 7 passes (nothing to brag about by no means)
Info
Elevation-1430'
Front tires-Bridgestone Potenza s-04
245/40/18
Rear tire-Bridgestone Potenza s-04
285/35/19
Race weight-3740
1st.
60ft 1.928
1/8 8.30 MPH-85.55
1/4 12.88 MPH-108.83
3rd.
60ft 2.100
1/8 8.52 MPH 85.81
1/4 13.10 MPH 108.77
4th.
60ft 2.14
1/8 8.52 MPH 87.07
1/4 13.11 MPH 107.30
5th
60ft 2.05
1/8 8.56 MPH 85.73
1/4 13.16 MPH 108.70
6th
60ft 1.98
1/8 8.316 MPH 86.06
1/4 12.89 Mph 108.96
7th
60ft 1.93
1/8 8.42 MPH 84.54
1/4 13.08 MPH 107.68
After my 7th run I got a massive tick going on some where on the top end and limp her home.
Info
Elevation-1430'
245/40/18
285/35/19
Race weight-3740
1st.
60ft 1.928
1/8 8.30 MPH-85.55
3rd.
60ft 2.100
1/8 8.52 MPH 85.81
4th.
60ft 2.14
1/8 8.52 MPH 87.07
5th
60ft 2.05
1/8 8.56 MPH 85.73
6th
60ft 1.98
1/8 8.316 MPH 86.06
7th
60ft 1.93
1/8 8.42 MPH 84.54
Village Troll
Usually when this happens after one has been revving to redline it can end up as a bent pushrod. It's possible your valve adjustment is out of whack. Take the valve covers off and see what you can see. Difficult to know how it did with no mention of modifications.
Found out a nut came undone on number 6 rocker exhaust. I'll take my times are a shame...I have 3.73s gears with a yank 3600. TFS 21* heads (cast) with a custom cam .577in 575ex. With 1.6 rockers. Full exhaust, 52mm tb, 30lbs injectors, EWP with cai. It's dropped on BMR 1.25' and has on car adjustable Konis. Adjustable panhard bar, and lower control arms with relocation brackets
Ooooo....totally forgot you had the heads and cam...regardless, you were consistent, and cut a good 60' for street tires. Have you ever had it dynoed? By your mph Id only guess your making about 330 to the tires.
*edit* online calculator confirms about 324 to the tires based on weight and mph, http://www.wallaceracing.com/et-hp-mph.php
I like them, but have only put a little over 2000 miles on them in 2 years. Me personally would go with the 40 side wall. Used to run a 285/35 and it was a harsh ride, go with a 40 and it helps a lot.
I don't know if you recognized my car but I was there all night and saw your car, looked great!
I got a whopping 14 passes in and bested a 13.34 @ 102. Had a bunch of consistent 13.5s all night. I hotlapped A LOT.
first pass was 68 degrees and rear tires had 40psi (fastest pass of the night).
Before my third pass I'd dropped them to 35psi. Then before my 6th passed I'd dropped them to 29 psi. By then the temp was 49 degrees. I tried flashing all the way once and spun like a **** (2nd pass). After that run I just eased out of the hole and then mashed it.
Thunder Valley Dragway, marion sd
