Looking for This part
I have order this part from 5 places just to receive a call or email saying they can not get since its discontinued. Anyone know a place i can get one please let me know so i can replace mine thanks Tom
LT1 Power distribution block
part number 12186586
Located on RF (Passenger) Shock tower area behind battery
And i know there are other styles of these blocks but i really like to keep it simple and make my engine compartment perfect. this part is keeping me from that goal
I didn't know year one had them I bought mine form the GM dealer they actually had it in stock and told me good luck if you break that one as you probably will not find another.
Ive needed 1 of those to but havent "got round to it". Seen them on ebay under camaro parts and every once in awhile notice them turn up when shopping for other parts.
Did u try a google for GM PART # 12186586? I got 3 hits. Heres one: http://www.gmpartsgiant.com/parts/gm...-12186586.html.
Hope this helps and please let us know what u find and where u find it.
cardo
cardo
You provided a sarcastic response to my attempt at providing another perspective. If you can't find the part brand new then you are SOL. Since you have already done some searching and placed orders with various folks only to have them cancelled, perhaps you should indicate who you contacted to assist those in helping you.
Try:
Newgmparts.com
gmpartsdirect.com
Try:
Newgmparts.com
gmpartsdirect.com
Im with blackbird on this one. Those wires are horrid to look at, and tucking the wires is a great way to make the engine bay look a LOT better. Show cars this old really shouldn't look like a stock car that has been in climate controlled storage all it life. Put some personality in your car. just my .02
Well black bird sorry about my response I took your advise and now my wires are all tucked including my fuel lines, injector harness, now I need to hide the power steering tank and relocate coil and icm. Then to fill holes and repaint
Not to bash anyones efforts but is the wiring still out of the weather when on the other side of fender? Do u have to extend any wires to move it there? I see ebay carries the stud for this in black or red so relocation is possible. My car is not worth making it fancy but interested in how its done. I guess what im really worried about is do u have to remove the fender liner to do this?
FYI GMpartsdirect is OOS on the 12186586 and the other link Newgmparts wanted nearly as much for shipping and handling, $12 jumps to $23 when totaled. Who knows if they will come back OOS anyways so i cancelled.
cardo
cardo
I did order one from gmparts, yesterday we will see if they send one or email me saying discontinued.
As for hiding the wires I drilled 2 holes all the way in the rear of the wheel well once the cover is removed, one on each side about 1.25 in.
Then i unhooked the hood latch cable, fuel lines, and misc wires i had. I put one through hole at a time making sure none were tangled up. Zip tied everything after I pput wire covers on it all and electric taped it closed.
That was the driver side
the passanger side was a bit more work.
same hole as driver side location
these wires have disconnects
Un hook them both
disconnect ground
disconnect power from red block
Disconnect vac hose from ac box
remove tire and liner from wheel well
fish wires through hole you drilled
i moved my ground down so when i tapped it you could not see any of it
the power i used a stereo power block and used small screws to hold block.
The end result is a very clean look but now I want to hide it all. Took 2 hrs total and I was driving again
Un hook them both
disconnect ground
Thanks i also forgot to mention the holes should have a protective barrer so nothing can rub holes in wires or fuel lines, i used a heater hose cut long way in half then ziptied so it wont move. The hose sticks out of the hole 1/4in in the compartment area.
