untuned run a 8.1375 @84.. gains of a tune?
96 trans am, a4, 3.23, cc305 cam, tci 3000 stall, long tube headers, y pipe , flow master.. run a 8.1375 @84 1/8 mile untuned.. I just paid pcmforless mail order got send pcm to them now.. what gains should I get from a tune?
What was your 60'? I ran 8 flat @ 80 with an intake/exhaust suspension 3600 stall car with a 1.66 60'. The car probably has a lot more in it with a good dyno tune, I picked up like 40 horse with a nice tune
Let the tuner decide, just give them your cam specs, that's their job....I would assume 500 rpm or so over the RPM the cam peaks at: 5500, so probably 6000-6100 range while also raising the rev limiter to 6200+...you got roller rockers and upgraded springs? You probably need them to turn more RPM or you get valve float with weak LT1 factory springs, and 1.6 rockers are a proven 15+hp gain. Once you get the tune in order, I think that goal is attainable.
guy that done heads put some springs in them. he said he set them for 550 lift.. I want some 1.6 roller rockers. think it be ok to run them? gains?. sixty foot was 1.77
Probably at least 2-3 tenths....maybe 5-10hp with a cutout, you have to get it tuned for the gears obviously, so best to let the tuner know when you mail the PCM off. You got some sticky DR's? Get those and some boxed/tubular control arms to eliminate axle hop and really take some time off your ET.
so here what I have done to car going to track next week..
pcmforless tune
3.73 gears
tb bypass
front sway bay removed
umi lca
swapped my front wheels from 18 to 17 in ones
3 in cut out (remember I have flowmaster)
60lbs diet
how much gain should this get me?
7.8 maybe?
pcmforless tune
3.73 gears
tb bypass
umi lca
60lbs diet
7.8 maybe?
im hoping gears, sway bar and lca will help 60ft
