converting sbc heads to lt1 heads?
Old 05-10-2014, 11:28 AM
rjmarazzi's Avatar
Default converting sbc heads to lt1 heads?
I know this has been asked before I just wanted some input. I can get a set of sbc Afr 227 heads p/n 003-1121 for very cheap almost stealing cheap. Is it worth converting them to lt1. Also I have a all forged and studed 355 that is turbo Charged but i can get the afr's for 800 bucks.I know they sell them in lt1 form but they are over $2000
Old 05-10-2014, 11:30 AM
rjmarazzi's Avatar
Also do you think they would be two much for my application.
Old 05-10-2014, 11:41 AM
Puck's Avatar
Those are amazing heads, but are not meant for a small street combo so it depends how aggressive your turbo build is. They have some nice big chambers though, so it may drop your CR and allow you to run more boost and make even more power.
Figure ~400 for the conversion, so you'll have around 1200 in them which is still a steal.
I would definitely get them, but if your build is just an 8-10psi modest street car then you won't be taking advantage of them.
Old 05-10-2014, 11:51 AM
3.8redbird's Avatar
Or hit me up and I will take them for $1000 and you make $200.
Old 05-10-2014, 11:53 AM
rjmarazzi's Avatar
I want to run at least 20 lbs of boost it is not a daily driver
Old 05-10-2014, 11:55 AM
rjmarazzi's Avatar
I am already running a single plane intake a victor Jr with bungs for injectors.
Old 05-10-2014, 12:34 PM
duh
duh's Avatar
If get them either way. Either you use them, or convert them and sell them. Either way you'll make money.
Old 05-10-2014, 11:15 PM
Man-Crush Warning
Shownomercy's Avatar
20psi is like straight race car LT1 bro
Old 05-11-2014, 09:04 AM
PA94Z's Avatar
What is your fascination with race car vs street car?? Did I miss a thread..
Old 05-11-2014, 05:01 PM
Man-Crush Warning
?? 20psi on a decent motor is a lot of power, figured it would be raced.
Hence the comment. Dunno where street car entered things?
Old 05-11-2014, 08:41 PM
rjmarazzi's Avatar
It will see alot of the track and some street. I just went and picked up the heads I will post some pics when I have a chance.the guy even gave me some new sheet metal valve covers with them.
Old 05-12-2014, 06:21 PM
rjmarazzi's Avatar
Ok here are a few pic's. Also what was the name of the company that converts them to lt1.
Attached Thumbnails converting sbc heads to lt1 heads?-1399936177738.jpg   converting sbc heads to lt1 heads?-img_20140512_175957.jpg   converting sbc heads to lt1 heads?-img_20140512_175628.jpg
Old 05-13-2014, 01:53 PM
rjmarazzi's Avatar
what was the name of the company that converts the sbc heads. I am going to send these heads out to have them converted.
Old 05-15-2014, 03:58 PM
rjmarazzi's Avatar
ttt bump
Old 05-15-2014, 05:20 PM
Moderator
BizZzatch350's Avatar
There was a place in Indianapolis? that was doing the conversion, LME in Houston did a few when they first started. I doubt they would do them any more.
Old 05-15-2014, 07:28 PM
Puck's Avatar
Port Pros used to do them as well.
Old 05-16-2014, 08:26 AM
Man-Crush Warning
Have you talked to LE ?
Old 05-17-2014, 06:05 PM
rjmarazzi's Avatar
I talked to him about my cam. I didn't even think about asking him I will call and see on Monday. Thanks for the advice
Quick Reply: converting sbc heads to lt1 heads?
