95 trans am Lt1 issue
Old 05-14-2014, 08:45 PM
hypno92's Avatar
Default 95 trans am Lt1 issue
Get up in the morning start the car fires right up, let the engine warm a bit and drive it 1/4 mile and no warning no sounds motor just shuts off and won't start back up just cranks. After 15 cranks it'll start but runs bad backfires and rpms are all over the place?? What is going on
Old 05-14-2014, 08:47 PM
hypno92's Avatar
While its running bad after the engine kills off it stalls most of the time within seconds
Old 05-14-2014, 08:55 PM
Cajun ELESS-ONE's Avatar
try a new icm. when they get hot they can cause that issue. let it cool down and start it. if it starts fine and starts messing up after ithe same amount of time then its a strong possibility its the icm.
Old 05-14-2014, 08:59 PM
cardo0's Avatar
I had an opti that died a slow death like that. It would just quit on its own and continued to get more frequent. Finally wouldnt start anymore. U should have some codes. Always read your OBD codes.
Old 05-14-2014, 09:38 PM
hypno92's Avatar
My car throws no codes,a month ago I just put a new fuel rail,fuel pressure reg,opti,plugs and wires and it fired right up and drove awsome for about a week and a half. Then one day driving down the road the motor just stalled but it started right back up and it just got worse as time went on now it starts and I'll drive for 1\4 and it will kill out and takes like 20 cranks just to get it able to idle to the driveway!sometime when I turn the acc on the fuel system electronics go on the fritz with the radiator fans? I'm lost honestly
Old 05-14-2014, 09:44 PM
SilverSS07's Avatar
What brand opti did you put in?
Old 05-15-2014, 06:54 AM
hypno92's Avatar
Ac delco
Old 05-15-2014, 07:50 AM
shbox's Avatar
When is the last time you actually scanned for codes? You can't rely on the check engine light, because some codes don't make it light up.
Old 05-15-2014, 08:53 AM
ThoR294's Avatar
^ correct, and it may store history codes. light wont be on for history codes
Old 05-15-2014, 10:17 AM
hypno92's Avatar
I haven't scanned it yet I need to find an obd1 scanner with an obd2 connection port adapter
Old 05-15-2014, 10:21 AM
ThoR294's Avatar
you can use a paper clip. should be on shbox's website on how to do it
Old 05-15-2014, 10:43 AM
hypno92's Avatar
Any idea on what you think its going to turn out to be?
I was hearing knock sensor or cloggle fuel filter
Old 05-15-2014, 10:58 AM
ThoR294's Avatar
could be anything really
Quick Reply: 95 trans am Lt1 issue
