11's stock bottom end w cc306 cam
Old 06-07-2014, 10:00 AM
lt1 power's Avatar
Default 11's stock bottom end w cc306 cam
Went to the track last night with my 94 trans am ran a new best 11.76 at 116 mph on a 1.64 60 ft. Car has 3600 stall and 3.73 gears and stock mildly ported heads with boltons and a few suspension upgrades. Shooting for low 11s at about 120 mph with this setup just need some more weight reduction and suspension upgrades first. The fastest car I have ever seen with this cc306 cam ran 11.18 at 121 and 9.83 with a 175 shot.
Old 06-07-2014, 11:41 AM
azmarkus's Avatar
Very nice times; I assume you use pusher fans and an EWP?
J/K; srsly, good run!
Old 06-07-2014, 09:54 PM
lt1 power's Avatar
Stock water pump and fans. Near full weight car.
Old 06-07-2014, 10:12 PM
350 groundpounder's Avatar
I wonder what realistic times a m6 lt1 could run with the super streetable low-mid torque monster cam "Crane 227" ? Cam with roller rockers, stock heads, CAI and Headers, stock 342's in back. Rear wheel HP? I heard this cam is a beast for street driving.
Old 06-07-2014, 10:41 PM
NewOrleansLT1's Avatar
Good times considering the how hot it's been outside.. Work on that 60ft and drop some weight you might can pull a 11.5x-11.4x judging off your mph
Old 06-07-2014, 10:49 PM
lt1 power's Avatar
My next mods will be bmr torque arm and v6 springs with rr airbag. And ptake out some weight.
Old 06-07-2014, 10:57 PM
94 z28 A4's Avatar
Very nice times! Sounds like a good setup you have!
Old 06-08-2014, 02:07 AM
rare01Vert's Avatar
Great times! The 'ol CC306 rocks. I always wanted to run that cam but went with the 847 instead.
Old 06-08-2014, 02:43 AM
hrcslam's Avatar
Great time. 2 seconds faster than mine. What was your DA?
What rear end are you running?
Old 06-08-2014, 10:14 AM
Moderator
BizZzatch350's Avatar
Car's running good, especially for the weather, I am sure you'll be able to work it down a lot deeper in to the 11s. A lot of the "best" times people put in their sigs were set on Negative DA days. We used to see that a lot down here in Houston. Guys would wait till January when HRP opened back up after Winter Holidays and run these monster times in mine shaft air and put it in their sig saying thats what the car ran.
FrankB ran it in his Z28, 3350#, car ran 11.40s with it. Fairly Light car.
Old 06-09-2014, 01:20 PM
lt1 power's Avatar
DA was around 700, and weather was in the low 70's, car still has stock ten bolt just have gears only, no girdle or anything stock rebuilt transmission with revmax 3600 stall. guestimate around 400rwhp. shooting for low 11's if everything holds up.
Old 06-09-2014, 02:02 PM
transbird95's Avatar
Nice times! Not bad weather either. When I race it is usually like 25-3500 ft...
Old 06-09-2014, 02:18 PM
hrcslam's Avatar
Thanks for the info, added to this thread. Gathering data.
I wish I had your DA. Mine on Friday was 5600. Ugh.
Old 06-09-2014, 02:50 PM
lt1 power's Avatar
Wow!!! didnt know how lucky I was with the DA here in VA, I race at the same track Richmond Dragway, Joe Overton used to race at, record holder for the fastest n/a lt1 ever.
Quick Reply: 11's stock bottom end w cc306 cam
