Can i change to ls7 lifters, 1.6 rr's, and pshrds with no problem?
Old 06-24-2014, 09:20 AM
Formula313's Avatar
Default Can i change to ls7 lifters, 1.6 rr's, and pshrds with no problem?
I have lt1 with 129xxx, basically stock just Lt headers, 3in exhaust, & CAI
Old 06-24-2014, 09:31 AM
Man-Crush Warning
Shownomercy's Avatar
Why would you want to.
Old 06-24-2014, 09:41 AM
Formula313's Avatar
... performance
Old 06-24-2014, 09:56 AM
Man-Crush Warning
Do you have shot lifters and bent pushrods currently?
Old 06-24-2014, 10:09 AM
Formula313's Avatar
No but the pushrods are mix matched from previous owner and I know that's not good. So I plan to do this, & later along with a cam. I was just wondering will this set up work properly with stock springs, So I can put it in now & the cam and springs in later...???
Old 06-24-2014, 10:35 AM
93M6Formula's Avatar
The lifters are a waste of time, if yours work, leave them alone. 1.6 RRs really need at least an LT4 spring or similar to be safe with the added lift. Get a pushrod length checker and see what you will need with the 1.6rr's.
If you want to do this once, don't get cheap junk rockers either, look at Comp Pro Mag Ultras non self aligning and you will need guideplates.
Old 06-24-2014, 10:47 AM
Formula313's Avatar
Wassup formula. I was considering comp cam ultra gold aluminum rr ?
Old 06-24-2014, 09:58 PM
jay7199's Avatar
I have a LT4 spring kit for sale if you want.
Old 06-25-2014, 08:11 AM
grimmfenyaxi's Avatar
Old 06-25-2014, 08:16 AM
Those are fine, i'm just not a huge fan of aluminum rockers.
Old 06-25-2014, 08:17 AM
It WOULD work but not very safely. Replace them.
Old 06-25-2014, 10:50 AM
Formula313's Avatar
No! Like formula said.. it's not safe. & not worth it. Change the springs you might as well do the cam at the same time.
Old 06-27-2014, 02:57 PM
nitrous2fast's Avatar
Hey! be easy with that whole "You might as well do the _____ at the same time" thing. I did that once and well the whole drivetrain came out.... lol
Old 06-28-2014, 12:21 PM
DUDCOUPE's Avatar
I ran 1.6 rr on my stock springs just fine
Old 06-29-2014, 03:16 PM
Formula313's Avatar
Nah I wasn't being rude. I was just saying because a cam would be only a couple more hundred away
Old 06-30-2014, 08:37 AM
Congrats, doesn't mean it was smart.
Quick Reply: Can i change to ls7 lifters, 1.6 rr's, and pshrds with no problem?
