Lt1 383 air intake
this one:
http://www.knfilters.com/search/prod...prod=57-3022-2
Solid .1 and 1 mph over the LS1 lid and that was with the old 350 cam/heads combo. But you can't have a stock hood. I use a Suncoast WS6 on my Formula
lol that is interesting; you would figure that they would paint the barriers a different color or something after the mark... Or maybe a set of lights at the very end of the track that light up when you cross the beam.
this one:
I am also Leary of my stock but ported 95 intake, any ideas?
this one:
I do not believe the LT1 MAP accurate at WOT on modded engines, given the location I think the Bernoulli principle causes higher than true MAP reading once moving much more than stock airflow.
Seen a 355 with dual cone filters 3.5"pipe no MAF, monoblade register vacuum, not a snowballs chance it was legit.
Interesting. I'm reading 87kPa MAP at 94kPa Baro. So, you're saying that actual MAP is higher? I'm running a stock LT1 48mm TB and untouched intake manifold, K&N CAI intake, homemade elbow, and Spectre Cone filter 4".
I was thinking about adding the Chris1313 ram air to my SLP lid setup. Thought about adding some aftermarket bigger MAF ends but some people say they are more of a pain then they are a gain. Decisions decisions.
Here is a link to those RPM SPEED MAF ends.
http://www.ws6project.com/user_stor/...oducts_id=5780
I am following you. From what I have been reading it really skews the low rpm flow more than anything un tuned. That may be the reason why I also read tuners don't like to tune with the bigger MAF ends. The calibration being thrown off makes them a basket case to tune. Check this out though. Some of you might already know but I just found this and ordered one since I still have the original smaller 75mm or so stock MAF. Part number AF10056 Delphi MAF. I talked to my tuner Solomon and he told me he is running this MAF and it has similar flow characteristics and was told I would not need a re tune. I got one off of Ebay for $75 shipped. 10mm or so bigger in diameter and should not need a tune. I call that two birds one stone. Love it! Had to share this
