95 LT1 24X Conversion
I have a 95 Pontiac Trans Am with a LT1. I currently have decided that I am sick of the optispark issues that I am having and decided to switch to the EFI Connection 24x conversion with LS1 pcm. The question I have is I am decideing weather to buy the efi connection harness or use the psi wiring harness. I know that the efi connection harness is plug and play to the car and the psi harness requires some wiring for gauges, starter, power, and ect. Looking for some insight on what other users preferences are. Any info would be help full. Thanks
Well I know I changed from the Opti because of the tuning aspect. You can get much more out of the car from tuning than the Opti. With that being said, I would go with BP automotive harness. Plug and play, all labeled and good quality stuff. Waiting on mine to be shipped now!
This guy states it is "opti issues" which more often than not come down to neglect and incompetence of the owner especially on stock or mildly modified cars.
Yes it's In a shitty spot, but is an extremely precise ignition and people's lack of skills in diagnosing a cars condition ultimately ends up in the opti being blamed . .. These cars are 20 years old and are going to have issues with a harness wire cut, corroded , etc.
Fact. you will pick up NO horse power going 24 x... if the afr and timing remain the same threw out the pull how do you figure it's going to make more power? Maybe mystical unicorn In the ls1 pcm lol
Honestly... I'd replace the whole opti. MSD if you want. All though From what I've heard the MSD isn't really that much better. With the time and money you'd have involved with the 24x conversion (fairly hard modification) IMHO I would just replace the opti. Fairly straight forward job. Just take your time and do things right the first time.
The MSD is probably much more failure prone than an OEM replacement, and aside from venting on the 92-94 doesn't really offer any improvements in comparison. I also don't think that MSD uses the Mitsubishi optical sensor, which seems to be critically important. I think AC/Delco optis are all remanufactured now, unless you happen to run across new old stock somewhere, in which case you would probably be buying from a dealer, and paying through the nose. I think Delphi optis are still being manufactured, but I'm not even certain about that.
wtf! People come here for for advice not to be ridiculed from a a-hole! If you are unable to be polite and lend some advice to this member get off! This is a community of fellow car lovers
Yeah it is much more helpful to tell someone who can't diagnose and repair a presumably stock car that they should complicate and modify it so then they endup even deeper over their head and get discouraged right out of the hobby.
It is a sad sad day when common sense and truth even if unpleasant are considered terrible and we should blindly praise folks.
I have made plenty of bad choices and mistakes and value the input of those who set me straight more than those who would blindly praise anything.
