Need vacuum diagram 1993 LT1
Old 02-14-2016, 03:34 PM
Alaskanbadfish's Avatar
Default Need vacuum diagram 1993 LT1
I've looked online and can't find what I seek. I need a diagram without egr, or air system, vented opti. Only one I know I have right is the small line to fuel pressure regulator. Any help would be great!
Old 02-15-2016, 07:06 AM
myltwon's Avatar
If you still have the stock fan shroud on there it should have a vacuum diagram
Old 02-15-2016, 08:31 AM
shbox's Avatar
If he had a signature, people would know that this is a 93 LT1 transplant in a Jeep.
Any stock diagram you find, you can follow. The items you don't have get the vacuum source port capped off.
Your PCV valve hose is u-shaped, unlike this example:
Old 02-15-2016, 08:59 AM
myltwon's Avatar
Ah, I'm on mobile so I wouldn't have seen it anyways
Old 02-15-2016, 10:49 AM
So my pcv doesn't go up around to the throttle body, but just a port next to the pcv? Would the bottom port on the throttle body just be capped then? I'll work on that signature. Thanks!
Old 02-15-2016, 11:14 AM
Supercharged111's Avatar
The u shaped hose only applies if that's a 93 intake. Otherwise there's a longer piece the later ones use that runs toward the front. Wouldn't you know it, all my junk is either in the trailer or a friend's garage. The 2 bottom ports on the throttle body are for coolant. You can just leave them open if you want, I straight up yanked mine out. How about a couple pics of this thing?
Old 02-15-2016, 11:17 AM
shbox's Avatar
The PCV vacuum port on the front of that diagram is actually on the intake and not the TB. Your 93 intake has no port there (or it is plugged), because the PCV used a port on the side of the intake next to the PCV valve (that's why you have the u-shaped hose).
http://shbox.com/1/pcv_pipe.jpg
Your PCV in upper part of this diagram:
http://www.wholesalegmpartsonline.co...05MF03-076.JPG
Old 02-15-2016, 12:28 PM
myltwon's Avatar
94s or atleast the early ones, also had the u shaped hose.
Old 02-15-2016, 12:38 PM
lt1-xjs's Avatar
FWIW the only functional port you need is the fuel pressure regulator,everything else can be capped off. I do have a line for my hvac and cruise only because I wanted them to work. I have a pcv valve in my pass valve cover hooked to the throttle body. It also has the U hose.
Old 02-15-2016, 02:06 PM
shbox's Avatar
I didn't mention it since he has a 93.
Old 02-15-2016, 02:33 PM
Thank you. I'll fab up a u shaped hose tomorrow.
On the passenger side of the TB there is a strong vacuum on the bottom, this is capped as well I assume?
Old 02-15-2016, 02:46 PM
Yeah. The upper goes to the passenger valve cover, that's the other half of your PCV system.
I misread one of his posts in a way that implied he may have a later intake. Having re-read I don't think that's the case.
Old 02-15-2016, 03:16 PM
Right, top port goes to pass valve cover, bottom port has strong vacuum and is just capped off right?
Old 02-15-2016, 03:26 PM
Yeah, at least that's how I have mine. I'm guessing it's for my non-existent charcoal canister.
Old 02-15-2016, 03:34 PM
shbox's Avatar
Might be better to buy the correct, pre-bent hose if it is still available. Otherwise, you might end up with a kinked one that does not work.
Yes, cap the port on the TB that would be for EVAP.
Old 02-15-2016, 03:35 PM
myltwon's Avatar
meant to quote supercharged111 in that reply
Quick Reply: Need vacuum diagram 1993 LT1
