fuel rail o-rings
Old 03-29-2017, 09:12 PM
Snow Dog's Avatar
Default fuel rail o-rings
Anyone know a source for the o-rings for the fuel rail and tubes? I'm rebuilding my rails since finding the o-rings cracked. I can't seem to find a source for the o-rings though. I can find them for the L98 motors but I don't know what sizes they used. I'm replacing the FPR and it comes with o-rings. If I can find the other o-rings then everything will be new on the fuel rails.
Thanks
Old 03-29-2017, 09:15 PM
94_LT1_TransAm's Avatar
Are you talking about the ones on the injectors? If so have you tried Rockauto? They have tabs under fuel and air labeled "fuel rail o ring", "fuel injector o ring" and under the fuel injector o ring tab they have a whole kit in there.
Old 03-30-2017, 06:31 AM
leadfoot4's Avatar
Fel-Pro part number ES70599. Check with your local auto parts store.....
Old 03-30-2017, 08:41 AM
Snow Dog's Avatar
No, not the injector O-rings. I'm referring to the two O-rings that are on either end of the crossover tube found on late LT1 fuel rails and the o-ring that goes on the end of the tube that slides into the FPR. There are only three O-rings total I'm trying to find. The crossover tube uses 3/8" and the FPR tube uses 5/16" O-rings.
Thanks
Old 03-30-2017, 08:44 AM
shbox's Avatar
Since you know the sizes, you should be able to take them to your local NAPA and get them to match some up.
Old 03-30-2017, 10:03 AM
Snow Dog's Avatar
That's definitely a possibility, Rob. I just haven't made it that far yet. I thought maybe I was looking in the wrong place or that someone knew who had the parts. I'm surprised with the number of LT1 vehicles that were built that more people haven't had to replace their O-rings or that a company doesn't already have them as an available part.
Thank you!
Old 03-30-2017, 01:01 PM
leadfoot4's Avatar
I sold my LT-1 powered, '96 Z/28 a couple of years ago, but I'm pretty sure I remember the O-rings you're referring to. If I recall correctly, they aren't easily replaceable. I thought they were "swaged" in place, so as much as I wanted to replace them before they dried out and started leaking, since they weren't broke, I didn't try to fix them.....
Old 03-30-2017, 04:42 PM
383z's Avatar
I always wondered this too, because I want to take apart my fuel rails and polish the crap out of them.
OP, let me know what you find out.
Old 03-30-2017, 09:31 PM
Snow Dog's Avatar
I will. I should be able to make a trip to NAPA within the next couple days.
Old 03-31-2017, 12:54 AM
ACE1252's Avatar
I was having trouble finding the o-rings and caps for the Ford 30# units. This company had a kit for them. Hit them up with an email or call, they may have a kit for what you need as well.
Marren Fuel Injection
http://www.injector.com/
Heck, the same kit I got may be what you need....
http://www.injector.com/cart/pc/view...&idcategory=10
http://www.injector.com/cart/pc/view...?idCategory=10
Old 03-31-2017, 01:00 AM
pdxmotorhead's Avatar
Suggestion,, I get my o-rings from hydraulic supply hoses.. almost infinite selection.
Old 04-02-2017, 10:27 PM
Snow Dog's Avatar
That's a good suggestion, pdx.
I just ordered in some o-rings from McMaster Carr. I ordered part numbers 8297T168 and 8297T169 which are 5/16 and 3/8 inch Viton o-rings respectively. They are almost identical to what I measured so I figure my measurements aren't exact. I'm not positive on the durometer, but from experience, I can say the factory o-rings are on the harder side of the scale like these from McMaster. Will let you know what they are like in a couple days.
Thank you
Old 04-03-2017, 01:19 AM
RGSS's Avatar
I bought mine off ebay.
Brown viton o-rings size 110: 3/8 x 9/16 75 durometer hardness
50 units for under ten bucks. These are for the crossover tube.
Worked great
They carry all the sizes for the fuel rail and injectors
Quick Reply: fuel rail o-rings
