ABS light and some times engine light but it gos away
Old 01-27-2006, 11:08 AM
95formulalt1's Avatar
Unhappy ABS light and some times engine light but it gos away
sometimes my ABS light comes on and stays on until i shut off my car......and sometimes my engin light comes on to but it always gos for a few mintes later.. anyone have this problem??? or know how to fix it??? the ABS thing pisses me off. ....the engin light has not come one in a long while so i am not to worry abouth that just ABS light!!!! any help would be great thanks
mike
Old 01-27-2006, 02:50 PM
anybody know???............
Old 01-27-2006, 05:35 PM
n2ocamaro's Avatar
There are several things that can trigger an ABS light. Brake light bulbs out, ABS wires close to spark plug wires, low voltage problems (like a bad connection at the battery) and wheel sensors. I had one of the wires to one the wheel sensors chewed through by the front tire when a shop didn't get the wire back into the retainer clip after a spring/shock install. Then a had a bad ground connection at the battery that caused the light.
Old 01-27-2006, 06:46 PM
ooo...could it be from my under drive pully?? when the is at a red light it idles low
Old 01-28-2006, 12:54 PM
n2ocamaro's Avatar
Oddly enough no. I have underdrive pullies and it doesn't trigger the light when the voltage drops at idle. I am not sure why that is now that you mention it.
Old 01-28-2006, 02:29 PM
mmmmmm
Old 01-30-2006, 03:19 PM
Togo's Avatar
my '92 vette had similar problems - they all went away when i replaced my TPS
i don't know why or how, but haven't had a code since - before you go just replacing it, you should test it to make sure it's functioning properly.
Old 01-30-2006, 09:35 PM
i will give it a try!
Old 01-31-2006, 01:48 AM
Chance883's Avatar
I had the same problems and it was the ABS sensors.
Old 01-31-2006, 11:42 AM
Togo's Avatar
now that i think about it - perhaps it wasn't the TPS - but i would still check it.
my vette did this when i would slam on the brakes and the pedal felt funny.
what ended up fixing the problem was a complete brake fluid flush (well maybe that wasn't all - we also changed my rear brakes while we were at it.
i also heard that if you have "magnetic dust" around the sensors you should clean that away first - it might not be a defective sensor, just a magnetized one that needs to be cleaned!
Old 01-31-2006, 02:21 PM
my brakes work great......i had the back ones done a lillte while ago.....the light justs comes on.........
Old 01-31-2006, 02:26 PM
Togo's Avatar
well check for the magnetic buildup around the "inside" of the dust shield (i'm assuming it has rear disc brakes) and by inside i mean under the car the side that points to the other wheel
if it has drum brakes, check on the ouside of axle housing.
and if you haven't ever done it, i recommend a system flush - you can buy a DIY pressureized power bleeder
hope ebay links are allowed
http://cgi.ebay.com/ebaymotors/Unive...spagenameZWDVW
i got a buddy that bought one of these - said it was the BEST $60 he ever spent - he did his car, and we did mine just a few weeks ago.
i think a power flush is $125 at your local brake shop - so here's a way to "stick it to the man"
Old 01-31-2006, 02:55 PM
thanks man for the help!!!
Old 01-31-2006, 06:22 PM
MattZ28's Avatar
Get it scanned - there are WAY too many possibilities to just guess, and you're going to waste a lot of money by playing the guessing game.
Old 01-31-2006, 06:25 PM
i did that....nothing!
Old 10-25-2007, 01:24 PM
BIG_T's Avatar
u ever get it figured out ?
Quick Reply: ABS light and some times engine light but it gos away
