loss of spark no prior symptoms
i had the back of the car jacked way up in the air and the car will not start now ran fine before and nothing i replaced the ICM and still no spark tryed a test light going in to the ICM had power out of the ICM power shuold i have a spark jumping from the coil line to the opti if i take it off cuz i dont the car doesnt fire at all what could cause this? i am in a hurry to get the car fixed any suggestions would be great what is up with the valet system thing what is that?
Did You check to see if there are any burnt fuses? maybe when You jacked the car up something came disconnected or something shorted out causing a fuse to blow. Do You have any DTC's?
you should Check for spark at the coil. take out the wire at the coil (CAREFULL!!) hold a screw driver in the wire to make the airgap shorter between coil and wire while someone cranks the engine a few times...if you see a spark check something else remember you need Fuel, spark, and compression if you jacked the rear of the car up did you mess with the fuelpump wires?
i have fuel i havent blown any fuses and i dont have power to the icm now it is a 94 z28 there is a wire from the computer it i think is supposed to give power to the icm it is white it goes to the pcm and has continuity from the icm plug to the pcm plug but doesnt have power all the fuses are fine and i definately dont have spark!!! REALLY ANGRY
I'm not sure if the F-Bods have them, but many cars with OE electric fuel pumps have a switch that kills the pump in an impact. If you had the car way up, and the car had one of these switches, you might have tripped it.
If the car has one, it might be mentioned in the owners manual.
