Shon Herrons Bolton Record Z28
Old 04-24-2006, 03:11 PM
METALBEAST's Avatar
Default Shon Herrons Bolton Record Z28
Here is a little video Sslow 4.8 put together of Shon's legendary 97 Z28. Enjoy!
http://media.putfile.com/Herron-Performance
Old 04-24-2006, 06:24 PM
chevy94c's Avatar
Cool video
Old 04-24-2006, 07:26 PM
MrBill97396's Avatar
How much does the car weigh ? and how much N2O was it on ? How long ago did the 7.47 pass happen ?
Old 04-24-2006, 07:28 PM
slolt1's Avatar
if i am not mistaken it is all motor
Old 04-24-2006, 07:49 PM
flyinZ's Avatar
Yep, all motor, SI I believe...probably around 3000lbs.
Old 04-24-2006, 07:55 PM
METALBEAST's Avatar
Wow! You people have not heard of this car? I had lunch with Shon on Saturday. Car weighs 3100 lbs with driver. No nitrous. Full Boltons, stock cam and heads. This car holds the LT1 bolt on record of 11.8@114.
Old 04-24-2006, 08:02 PM
kyles2000z's Avatar
yep all throttle no bottle. seen the car run a few times and its very impressive.
Old 04-24-2006, 08:03 PM
Nope never heard of him. Bolt on N/A record. Does it have a 4L60E or a th-350/or 400 ?
Old 04-24-2006, 08:18 PM
METALBEAST's Avatar
Six Speed
Old 04-24-2006, 08:50 PM
Shon Herron's Avatar
1997 Z28 T-top M6 3100ish RW with 240# driver (Russ). Moser 12bolt 4.33s/spool.
Spohn Adj TA, Drag Bar, Herron Performance LCA/PHR/Tuning, Hooker Headers and y-pipe. BMR K-member, U/L A-arms, Warrior Rims, 1 seat, alt relocated, 1 12" fan, 4" pin on cowl hood, !interior, !HVAC, SJM !ABS/LL, LW Battery, LT4 Springs/locks/retainers with Pro Mag SA 1.6RRs, APC Steering wheel, !Air bags, EWP, CAI, 52mmTB, solid motor mounts. (if I left anything out it was not on purpose.)
The 11.80 pass was made with a Spec Stage III disk but stock PP/TOB<--not a good set up. It doesnt have enough clamping force.
The M6 will be replaced with a T-braked TH350 and 4-4500 stall.
Engine will be replaced with a new bullet, after the 11.80 pass it started having terminal issues, rod bearings have determined to be unhappy.
I will either put a stock short block in it and go run some 11.60s OR more than likely do a cam/stock heads thing and run 10.9s, it will be over 100#s lighter once it hits the track again, which will not be anytime soon.
FYI-no clue the amount of power making it to the rear tires, it was to be on the dyno/WBO2 this month but due to the rod bearings being a bit fragile it will not make it.
Also, the 11.80 pass was 3/25/06 at Carolina Dragway in Jackson, SC.
Old 04-24-2006, 08:58 PM
97blkz's Avatar
As I always say impressive, get back and going Shon!
Old 04-24-2006, 09:23 PM
urbanhunter44's Avatar
Sick video
Old 04-24-2006, 10:54 PM
96silverram's Avatar
Looked real Nasty yankin the fronts
Old 04-25-2006, 08:45 AM
lt197formula's Avatar
thats damn impressive
Old 04-25-2006, 02:20 PM
LT14LIFE JT's Avatar
Damnit!!!! Sorry to hear of your misfortune, Shon. I hope you go back with stock longblock and get that 11.5 and then to TH350 for some sub 11.50s..With a freshened LT1, 100lbs lighter, and a tune, I don't see why 11.5-11.6 aren't attainable. Good luck.
Old 04-26-2006, 06:58 AM
GreenbeanZ28's Avatar
Heh, I keep thinking about buying some lightweight parts from Herron Performance and smoking Shon's record. Lol. I'mma building the car first, and if I dont have any cash left over for badass motor, I'll toss in stocker and run it!
Russ' Pro Shifted 6 speed>Shon's t-braked th350.
Old 04-26-2006, 07:10 AM
Z284thgen's Avatar
what shocks where run on the fronts and rears
Old 04-26-2006, 07:38 AM
Sorry I left that out....
QA1 12 way shocks (non Rs) and the 275# springs.
Rear shocks and springs are stock.
Old 04-26-2006, 07:41 AM
Bring out that bucket, we'll line 'em up!
Old 04-26-2006, 10:37 AM
SSlow 4.8's Avatar
that video turned out really good actually.. thanks for the compliments... maybe after shon gets the car togetther again we can get some even better footage.
Quick Reply: Shon Herrons Bolton Record Z28
