lt4 km
lt4 km
where can i find one and does anyone have a diagram of where it goes/connects? also is it a pain to install or a saturday morning piece of cake?
thanks in advance
thanks in advance
Well I don't have a picture but your computer is in the far back corner on the passenger side of the engine compartment. You only have to take out two bolts and then slide out the computer. You will then need a torx, allen wrench, or small flat head screw driver to unbolt to more bolts that hold a little cover down. You might have to pry up on the piece a little and then when you lift that piece you see the LT1 KM pinch the clip on the front of it and lift.
It goes right into the PCM. It's easy as all hell. Just pull the PCM out of the mounting bracket, open up the panel, and you'll see it chillin in there. Pull her out.
Originally Posted by 3pnt4maro
ok i have always wondered whats the difference between the lt1 km and the lt4..can someone explain since were on this topic
since i have headers, is it sensing knock and "de-tuning" it by retarding the timing which in-turn makes my car slower? cause if so, then a simple $40 could go a long way.. right?
thanks in advance
thanks in advance
