Trans
Old 07-30-2006, 05:18 PM
onebadblackz's Avatar
Question Trans
Has anyone put a 700r4 in a 94-97 4L60E car?? I need to know what all I need to do it, I have a rebuilt 700r with complete b&m insides....
Old 07-30-2006, 05:51 PM
1SLO6's Avatar
Dont think u can since those years are eltronically control by the PCM. Speedo, shift solenoids, temp all those things inside the trany. I also beleive that the output shaft that go into the converter are different. You would have to by pass the PCM get a custom speedo made to work with your car.....Etc. by the time your done u would have wished u would have re-built your stock one. Trust me my buddy did a 200r4 in a LS1 it was a 3 week project. Crossmember, and all electronics.
Old 07-30-2006, 06:23 PM
redhot lt-1's Avatar
its do able but my trans guy told me that the 4l60e is strong and handle more horse power and as bad as i abused mine and it still shifts hard and on the money ever time i`ll never change it out for anything else
Old 07-30-2006, 06:54 PM
well I was told I can and this one is strong I need a TCI converter lock up thats it
Old 07-30-2006, 07:04 PM
Honda Hunter's Avatar
Youre correct. Are you asking or telling? Youll also need another t/b and something else but I cant think of it at the moment.
Old 07-30-2006, 07:15 PM
I'll down shift it myself
summit told me all I need is a TV cable if I dont want to down shift myself eveytime
TCI converter lockup kit
and I already no all my crossmembers with fit because I had it in the just to test and it drove ok...
Old 07-30-2006, 07:26 PM
Looks like youre set. Will this be a DD?
Old 07-30-2006, 07:53 PM
yep... to school and what not
Old 07-30-2006, 07:57 PM
I had a trans brake manual valve body 4r70w that I DD from DC to Annapoliss traffic, highway and city driving. It wasnt that bad but it wasnt no 5-speed. I started to miss the good ole days when my computer did all the shifting. I hated flicking that switch for lock up also. Couldve got a timer but, meh.
Old 07-30-2006, 08:00 PM
what converter lock up kit did you have??
Old 07-30-2006, 08:06 PM
TCI-376600 thats the part number at summitracing.com
Old 07-30-2006, 08:08 PM
Got everything from performance automatic in Gaithersburg. I dont know if they do GM stuff though.
Old 07-30-2006, 08:21 PM
that TCI one I dont think you have to flip the switch but you can
Old 07-30-2006, 08:33 PM
so what do you think will it hit better with the B&M shift kit and all???
Old 07-30-2006, 08:38 PM
Burning Rubber's Avatar
I am in the process of putting a 1996 LT1 in my 1991 RS with a built 700r4. I think it will be fine. Although it may require a new VSS and a different kick down cable. I am not completely sure of everything that is involved. But I am sure I will find out within the next month or so
Old 07-30-2006, 08:41 PM
not using a kickdown though VSS exactly what is that
Old 07-30-2006, 10:03 PM
anyone else does this or tried this or thinking about trying it?
Old 07-31-2006, 02:19 AM
Like 93 Vs 94. The VSS is a issue in most older to newer and vise versa swaps because the ppm is differnt through each generation. Becomes a issue if you want the speedo etc
Old 07-31-2006, 02:24 AM
but what is it
Old 07-31-2006, 02:31 AM
Vehicle Speed Sensor.
Quick Reply: Trans
