!! help my lt1 camaro idles too high @ 1500 !!
can anyone please help and tell my why my lt1 camaro is idling so high i have tried every thing new distributor ,new wires plugs, ingition module, ignition coil and if it might make a difference i have added some headers w/ a 3" system, if you have any ideas please let me know, i do appreciate any help.
check for a vacuum leak on the intake....
use brake clean and spray around the T.B. , the ports going into the heads and around the EGR. if the rpm changes while you're spraying, you have a leak..
Originally Posted by NXSLT1
Do you have an aftermark throttle body? BBK maybe?
I have a BBK and it broke where the thottle cable attaches to it. You must check to make sure the "two part" assembly did not come loose. It could just be slipping and not noticeable. It will give you major problems.
Originally Posted by Black97
Why? Has BBK any problems like this?
