is there such a thing as TOO much intake?
heres the deal, my motor is in my sig. Headers and boltons. I put a 58mm tb on because i got it for free and i plan on building the motor sooner or later. NOW my buddy has a 4'' intake tubes i can fab up for it also. I got room for it too. Now with the 58mm and the 4'' intake tube, is there too much air or no? Everyone says a engine is a big "air pump", so i got a crazy freeflowing exhaust now cant i even it out with a big intake?
is your trans vacum modulated? if not, you better tune the trans line pressure tables for it. if the tube leading to and from the MAF is bigger than the MAF openings, It drops velosity, so the readings can be a bit off. but the RAISS intake, a filter, hooked right on the MAF, and then a straight boot to the TB, and it works really well.... so i don't see why not. get the maf as close to the tb as you can, and it will likely work the best.
Originally Posted by Tapout911
It wont hurt but it may not help either. All that air has to have somewhere to go. A free flowing exhaust doesnt help a restrictive stock heads and cam.
I'm gonna have to disagree... it won't make up for the "bad" heads and cam, but it will help it.
it doesn't, any more. Don't worry about that part. but basically, more air is getting thru at a lower throttle (TPS), and the presure won't be high enough at less than WOT. (if it wasn't vac modded), but your ok, since it's all done by vacum, so the trans no longer cares what size the TB blades are.
Location: king of prussia, pa (home) and williamsport, pa (school)
No such thing as too big an intake on the LT1 IMO.
to sum up the whole mess of **** flying around, you're only going to need a bigger "intake" (everything before the intake manifold) if you measure with a vacuum gauge how much vacuum you have a WOT. if you're pulling over 2" of vacuum at WOT you have an intake restriction. Whether or not it's the filter, tubing, MAF (not really a concern for f-body guys since you have a 3.5" MaF), or TB, it indicates you need more air
Originally Posted by emerica4601
are you f'n kidding me? hell yeah there is. i take the word 'intake' as the actualy filter, piping, throttle body, and manifold. theres a whole velocity issue with lt1's wehre theres just no need for massive amounts of airflow into the intake manifold. you will lose horsepower. get rid of the 58mm and get a 52mm. and stay with a regular intake. there, you will gain
Can I get a picture of how you are running a 4" CAI I am very interested to see how you even made that fit...... I will give you my email if you have pictures you can send or post them here....... i didn't know it was possible to fit a 4" CAI around all the clutter....
read it and wheep!!! You are right, i barely fit my 3'' with the ABS box. But i deleted everything out so i got major room!! It basically goes down into the airdam, i cut a hole in the bottom plastic piece so the filter is actually outside the car getting nothing but cold air! And when the car is running, it sounds like i got a blower on the car with how loud the intake is sucking in air, its crazy.
the ram air intakes do work. ("SSRAI" aka clear image, or RAISS) they build a slight pressure, while they collect the air and help to move it on it. I said SLIGHT pressure, not 6 psi of boost. also, that air that is being forced into the big pan(like a raiss) is pushing warmer air outta the way. it also takes away alot of bends.
but by looking at that under hood pic, I don't think one is very doable.
