cam without heads
Old 09-17-2006, 03:39 AM
transambandit's Avatar
Default cam without heads
so if i put in a bigger cam, pushrods, springs, rockers but did nothing with my heads what could i expect?
Old 09-17-2006, 04:14 AM
daniel6718's Avatar
to be faster...
Old 09-17-2006, 04:22 AM
Boodyrider's Avatar
Hell, I did just the 1.6 full rollers on a stock cam and picked up about 20/20, with a tune.
You'll see benefits, but not as much as you might with heads/cam.
Old 09-17-2006, 04:23 AM
LT1BRN's Avatar
you will be some where between, 320 and 360 at the wheels, however, be careful with the cam choice as in, do u want to keep it when head work is due, do u mind High idle, what other mods are going to have with the cam only setup?
remember, big is not always better.
good luck,
Eyad.
Old 09-17-2006, 02:54 PM
so far i have pacesetter headers/ory and borla with an slp ls1 lid on my lt1 w/k&n filter, i was thinking about a 232/230 or so, maybe up to a 236/233. If i get one now i can do heads later on right? I am pretty much just wanting to do the cam tho because when my lt1 blows im eithor going to put a 408 stroker longblock or a 6.0 LS2 engine in it, but id like to see some gains without spending 1k on heads
Old 09-18-2006, 12:37 AM
Black30thz's Avatar
you absolutely need all of the supporting mods as well, they are listed in a sticky, like headers back and at least an intake
Old 09-18-2006, 07:29 AM
GIZMO's Avatar
A cam with a little more exhaust duration might work a little better.
Old 09-18-2006, 11:52 AM
i was looking at this thunderracing comp cam, 63-07-467-8 Comp Cams XFI LT1 Camshaft, 230 / 236, .576 / .570 113 LSA, Strong mid-range and top end power. Headers, exhaust, gears, converter, computer tuning recommended.
Old 09-19-2006, 11:13 AM
MrCadillac's Avatar
the 113 LSA is to tame the cam, and flatten the curve out. not the best idea if you ask me. you could make alot more power with a slightly less duration(224), on a 110-112 LSA. wow, I have never seen a site with so many over caming people.
Old 09-19-2006, 01:31 PM
yeah but with stock heads wouldnt i be better off with a little higher LSA?
Old 09-19-2006, 11:59 PM
bearcat's Avatar
i agree with getting it on a lower lsa. id go with a 230/236 110lsa.
i have to disagree with the lower duration for more power though, look at other peoples dynos. ive never seen a 224/230 make more then a 230/236. maybee if your talking in the lower rpms, yeah it would but who wants low rpm power anyways
Old 09-20-2006, 12:13 AM
91Z28's Avatar
And that is why they grind the cams advanced 4 degrees from the factory.
Quick Reply: cam without heads
