Camming 1994 Z
Camming 1994 Z
I have searched without a definitive answer. If I were to install a cam, for example LT4 hotcam, and use the unvented Opti, what all is needed to do the swap. I understand that I can't switch to a double roller timing set with this configuration. Also the pin from what I have read is longer on the cam. I don't want to convert to the vented opti. Although it may be the best option to do so, I really don't want to go that route since I have recently changed the opti. Also, what timing sets will work for this application. Thanks in advance.
To do a cam swap, you're going to need all the essential gaskets that will need replacing when you take the car apart (somewhat) and are putting it back together. Thunder Racing sells a 'cam swap gasket kit' which had all the gaskets I needed to do the cam swap.
Besides the gaskets, I'd say you're going to need some quality high temp RTV Sealant (preferably black) and a little bit of patience to get it done. There have been a couple recent threads in the LT1 forum alone where people asked what they needed prior to their cam swap. Definately take a look for those.
Yeah I have seen those but the issue I have is the hole in the center of the cam. They are different between the two different type of optisparks. They are driven different. Everywhere I have searched yields nothing specific for the 94 lt1. Everything listed as far as parts is 92-03 and 95-97, skips right over the 94. With that said, looking online @ summit shows the cams compatible from 93-97 yet the 93 and 94 are different than 95-97 from what I have seen on the optispark/cam sprocket/timing chain options.
I just did a cam swap this past weekend on my 94 LT1 and I used a cc503 and just shortened the dowel pin with a grinder. Just match it the stock cam when you pull it out. I also used a Lunati timing set and the chain was very tight! Unfortunately for us we have 3 choices when it comes to timing sets. AC Delco, Lunati, and the Comp cam set for like $500! If your interested I have a couple timing sets for sale because Autozone accidently gave me 3 timing sets so now I have 2 extra.
Thanks for the info! anyone have the dimension for the dowel pin so I can mic the new one?
