high performance oil pump
Old 01-07-2007, 07:50 PM
slckstr96's Avatar
Default high performance oil pump
does anyone know if there is a good high performance oil pump for lt1s?
Old 01-07-2007, 08:49 PM
96capricemgr's Avatar
Why do you THINK you need to "upgrade"?
Stock does not mean bad, the stock oiling works quite well, if oiling needs change due to a shortblock build then the builder should spec the pump.
Old 01-07-2007, 09:27 PM
1997bird's Avatar
Don't go high volume. You don't need it and will only lose HP from trying to turn the larger gear. If you feel that you need more, then just put a high pressure spring into it. But with the roller cam and rockers you don't need but a little bit of oil to lube things properly. Windage slows the motor down and HP is robbed.
Old 01-07-2007, 09:56 PM
95FbFormula's Avatar
I went with the melling m55a it is a high pressure pump already has the spring in it. Its about $29 from cnc-motorsports and you can get the driver shaft for about $8 which is well worth it.
Old 01-07-2007, 10:14 PM
seawolf06's Avatar
I got the same one, ARP driveshaft and melling pickup.
Old 01-07-2007, 10:22 PM
GIZMO's Avatar
Great way to lose HP in a N/A motor.
Old 01-07-2007, 10:25 PM
seawolf06's Avatar
Explain how you lose hp.
Old 01-07-2007, 10:27 PM
fergymoto's Avatar
More drag...
GIZMO's Avatar
It's simple physics. The more pressure you make the more HP it takes.
Old 01-07-2007, 10:29 PM
seawolf06's Avatar
That doesn't explain anything. You can have higher pressure with the same amount of flow(volume), all you do is make the diameter (cross sectional area) smaller. Therefore, you don't lose any hp. Fluid dynamics.
Old 01-07-2007, 10:33 PM
seawolf06's Avatar
Originally Posted by fergymoto
More drag...
MAYBE on a high volume pump, but the loss is minimal. Can you take into the account the possible hp gains of increased oiling causing lower temps and a more efficiently operating engine? These are all just theories.
Old 01-07-2007, 10:40 PM
GIZMO's Avatar
OK. You build a motor and try different oil pumps. Please post up your results and tell us which one makes more HP.
Old 01-07-2007, 10:43 PM
seawolf06's Avatar
Trust me, if I had the money I would try every different bolt on for the LT1 individually and list all the hp variations I could.
Old 01-07-2007, 10:47 PM
GIZMO's Avatar
As that is your answer, I am going to help you out and suggest that you stick with the factory oil pump.
Old 01-07-2007, 10:54 PM
seawolf06's Avatar
Both Thunder and Futral build motors with HV pumps all the time. Only reason I didn't go HV and chose HP instead is because I couldn't afford an aftermarket pan.
Old 01-07-2007, 10:58 PM
GIZMO's Avatar
OK. I give up!
Good Luck,
Daren
Old 01-07-2007, 11:02 PM
1997bird's Avatar
The high pressure pump will cause more windage due to more oil being sprayed all over the other engine parts. Windage will kill HP. Look at some of the motors being built for the engine masters challenge in Popular Hot Rodding. All of them are controling were the oil returns to the pan to minimize windage. I highly recommend staying with a stock oil pump, it is more than enough.
Old 01-07-2007, 11:06 PM
seawolf06's Avatar
I just read that the M55A pump with the white spring acts exactly like a stock pump until about 55psi. Then it provides a higher pressure than stock. Don't stock LT1's have a windage tray?
Old 01-07-2007, 11:14 PM
1997bird's Avatar
Yes but it isn't that great. It helps, but it is nothing like a aftermarket oil pan for oil control and effectiveness. If you can go to Popular Hot Rodding's web site and read about some of the Engine Masters Challenge motors. They show you the extensive amount of work done to control were the oil returns to the oil pan and how they keep the oil from splashing up onto the rotating assembly. And that is with useing aftermarket oil pans.
Old 01-07-2007, 11:16 PM
seawolf06's Avatar
Makes some sense. I'll read that asap. Thanks.
