Help!!!!!!!!
Help!!!!!!!!
I need your expert judgment I dont have alot of cash so I need to get this right the first time.I have a 97 Z28 with 50,000 original miles so far it has BBK thottle body 52 mm (prob should have got the 58),cold air,high flow cats magnaflow,and flowmaster,6M.Well im getting used to the power and I now need more.What would the best bang for my buck?Also want it more loud and rumbleee,any thoughts on what i should change or do to my exhaust?
your imput is greatly appreciated
I'd get gears first, most of the the lt1's came with the 2.73's, I have 3.73's in my M6 T/A, I wish she had 4.10's. Shes a little over 2k at 70 MPH. I've also got the ceramic coated Pacesetter LT headers, they are also a good investment. But depending on how much you want to spend I would go with the gears first, they are cheaper to get the job done right, if you get headers you might as well get a cat back unless you plan on running true duels, which I personally have, but wouldn't do again.
Originally Posted by hi officer
is the car auto or 6 speed?
6 speed manual
im dead on 2k rpm's at 80 mph with stock rims and 245/50/16 tires,,,another thing i was wanting is a little wider tire in the rear any suggestions??
He's an M6, which came with a 3.42. The only gear change that makes sense is a 4.10, if a gear change is in order.
You already have the rest of the exhaust, so a set of headers would finish what you have already started.
Next would be a good set of gears.
If you want to change the rear tires, 275x40x17 fit in the wheel wells with no problem. You could probably pick up a used pair of wheels in the For Sale section. But it will eat up a significant amount of $$.
And the 52 mm TB is the correct choice, since it matches the intake perfectly.
cant afford the 17in swap how bout 16?size?
