Car starts but then dies
Ever since I removed the balancer hub to replace the front seal my car will start but then die within a minute.Also when I was putting the hub back in I remember I turned the crankshaft a couple of times.Does anybody have an idea whats wrong with my car???? .......timing is way off??
no I didn't,the only thing I did to my car was remove the balancer hub,take out old seal,put in new seal,turn crankshaft a couple of times while trying to install balancer hub and then finally install balancer hub.
my car is doing the same thing. just started it up for the first time with new heads and cam with a double roller timing chain. it bareley starts then dies if you dont play with the gas. also the roller rockers are ticking like a deisel like the timing is off please help me too!
mine too. mine starts and stalls all the time now. i cant figure it out. im not about to start dumping tons of money into parts to fix it either.
sometimes mine will just turn over for awhile like there is no spark. then i turn the key off and on and it will sputter and shut off.
First off, the engine is internally balanced. Correct....Next I've seen some LT1 balancers with a weight on them..those balancers have to be aligned correctly. This mostly causes engine shaking. You might to check this first.
The hub position shouldn't have anything to do with the vehicle dying. As far as hub position, Thunder Racing sells a hub machined for a woodruff key so you don't have to worry about which way it came off.
