12's with a LT1
Originally Posted by ridethesmallbus1
your full of poo if you dont think you can find the answer on everypage of the lt1 section
HOW DO I DO A SEARCH on here
Long Tubes, full exhaust, a dyno tune or at least a mail order tune, gears, and sticky tires, and if you have an Auto get at least a 2800 stall converter. Should put you in the 12's with no problem.
lt1
depends on your location also. I had every bolt on with 3:73 and stall converter with the stock motor, and the best I got here in ohio is 13.3 at 100 mph. I ran 13.9 pretty much bone stock at 100mph too. so On a perfect day and if I would have had a better torque converter than a tci I might have hit 12.999 but its harder than it sounds to hit 12's. I got the 383 now and running 12.3 so I'm changing stuff to reach that 11 mark, its all in the takeoff at the track and weather conditions, wether you have the power needed or not.
