LS1 Driveshaft Benefits?
My driveshaft is out of balance and I figured if I'm going to take the time to take it off I might as well just upgrade...I see that some people have "LS1 dirveshaft" listed in their sigs...What is the benefit of putting this on vs. an LT1 driveshaft?
basically because all (except 2.73 cars) ls1 cars came with aluminum driveshafts. lighter, better balanced (from what I hear)
I'd like to find one myself as soon as I sell my Moser 9", and put the 10-bolt back in.
You will notice a world of difference, I did. They are lighter, weigh about 12lbs actually, and I have no vibration at all from 0 to 150mph.
You have to be careful of clearance, however. Most aluminum d'shafts are larger in diameter than the OE steel units.
I put a Lingenfelter aluminum shaft in my '96 Z-28 and had issues with the shaft hitting the e-brake cable mounts in the d'shaft tunnel, if I hit large dips in the road. My car has the Eibach lowering springs, and Energy Suspension poly motor and tranny mounts. Those mods added up to a clearance issue, and I had to put the steel shaft back in.
Originally Posted by Revelation Z28
youll spin the tires easier?
Direct bolt in for 82-02 from what I've been told repeatedly. Less rotating mass, and less vibration at higher MPH. As said, it doesn't hold the power as night.
I think the Ligenfelter is bigger than standard LS1
Well while my tranny is out might as well put in an ls1 alum. drive shaft and some new u-joints eh?
I have the original DS on my car so i'm sure it's just a little out of balance huh
