Looking To Carb An Lt1
WHAT ALL DO I NEED TO CARB MY LT1? iKNOW I NEED AN INTAKE CARB AND DISTRIBUTOR...... AND IF I GOT A DISTRIBUTOR DO I HAVE TO GET A SPECIAL ONE OR WILL ANY SMALLBLOCK CHEVY ONE WORK? AND A HEI DISTRIBUTOR WILL WORK FINE?
1st, hit your CAPS LOCK key.
2nd, easiest way is to get the GMPP LT1 carb intake. any other intake you'll have to modify a couple of the bolt holes. you'll also need either a opti block off plate for the timing cover, or just leave the opti in place. any distributor will work.
Originally Posted by plaf713
waste of time, just get a gen I engine if you want to go carb
gmpp makes a lt1 and an lt4 intake the lt4 has a little larger ports can i use the lt4 intake instead of the lt1 or will it not fit? whos carb should i go with and what size? i have been looking at the edelbrock thunder series AVS 650 or 800 cfms electric choke is one of theas a good one to go with?
Originally Posted by -PEPE-
I've seen quite a few of you NY guys doing this swap, in fact one of my best friends did it too, from Saratoga I think, he dropped a full second off his ET, it's a waste when you don't know how to do it right. But I agree with FI being the prime setup on our lt1s, it's just when you get to a point like where I'm at now, you start pricing something like FAST or BigStuff and for $3500 to set it up right, you can't help but look at going carb, it's just tempting.
i def agree with you, i just think to get an extra 20 hp out of a 400 hp motor, its not worth it, but in your case it is. by the way i am about 20 minutes south of saratoga. how do you knwo people there? i saw that you were from texas.
