low coolant light
Old 07-24-2007, 10:37 PM
1996Formula's Avatar
Default low coolant light
the lights on but im not low on coolant. is there a plug i can unplug to make the light go away?
Old 07-24-2007, 10:48 PM
TAdriver's Avatar
your coolant level sensor is bad. Its right below the fill cap on the radiator. It helps to take your battery out to get better access.
Old 07-24-2007, 10:49 PM
ThoR294's Avatar
have you changed your coolant recently? make sure you have no air bubbles in your system. to do that, take the cap off when the car is cold, and run it... till it starts to get hot (boiling coolant)
Old 07-24-2007, 10:53 PM
i havent changed the coolant. if i just un plug the sensor will the light go away?
Old 07-24-2007, 10:57 PM
ThoR294's Avatar
no. the computer will not like that
Old 07-24-2007, 11:12 PM
StealthFormula's Avatar
he is right my friends Z28 had the same issue
Old 07-24-2007, 11:32 PM
infinitebird's Avatar
that and open the bleeder screws until coolant comes out.
Old 07-24-2007, 11:38 PM
how much is the sensor?
Old 07-25-2007, 12:20 AM
ThoR294's Avatar
yeah, forgot about those im used to the old fashion watch the coolant boil
Old 07-25-2007, 02:53 AM
GunshotZ28's Avatar
Yeah I'm having the same problem with my '95 Z28. That light bothers the crap out of me when I take my car on long distance drives. It bothers me the most at night when I have my interior lights dimmed, it's the only one that blindes the hell out of me. How could I get it to cut off?
Old 07-25-2007, 04:01 AM
LT1
LT1's Avatar
All you have to do is disconnect the low coolant sensor wich is found under the radiator cap. but its at your own risk, if you have a coolant leak you wont know its low, best way to fix it by replacing low coolant sensor if its faulty.
Old 07-25-2007, 05:09 AM
SSweet97's Avatar
The sensor is about $50.00 or more at the dealer. I think it is a dealer only part. I happen to have a brand new one. I'll let it go for $30.00 + shipping.
Old 07-25-2007, 11:40 AM
scottso's Avatar
I paid just under $40 with shipping at http://vandevere.com/.
Some things I just don't want to compromise - I want to know right away if the coolant level drops. Like what was mentioned here - remove the battery, drop the coolant level a little and its a quick swap. You can have your tools out and put away in 30 minutes.
Old 07-25-2007, 11:51 AM
indirocz28's Avatar
Its a pretty common problem really.. Not only on these cars but on fords as well..
lol
Old 07-25-2007, 01:18 PM
Chrisbequick's Avatar
I'll take it. PMing you now.
-Chris
Old 07-25-2007, 01:54 PM
TheTransporter69's Avatar
yeah people told me that, but you won't think its low anyway when its on because your thinking its just on becuase its bad so its fine ethier way.
Old 07-25-2007, 03:49 PM
GunshotZ28's Avatar
What does the coolant sensor look like, anyone have a pic. on hand?
Old 07-25-2007, 03:58 PM
scottso's Avatar
If you haven't been to this guy's site - set some time aside. He is some kind of superhero....
http://shbox.com/1/low_coolant.jpg
Quick Reply: low coolant light
