ignition problem
Old 08-05-2007, 11:07 AM
383lt1impala's Avatar
Default ignition problem
lately i feel my ignition system is falling apart when im on the freeway in 4th when i give it bearly enough throttle to downshift it goes to realll low rpm then the engine starts shaking the whole car but it doesnt make loud noises and most of the time it idels real rough should i change the opti and plugs?
Old 08-05-2007, 11:22 AM
LT1Falcon's Avatar
i thought that when optis start to go out they are first noticable as a high rpm miss. could be tho. check for burnt wires first
Old 08-15-2007, 12:48 PM
ok ima order the new opti what else should i order like in the coil ignition box etc and where should i buy them from
Old 08-15-2007, 01:43 PM
FAD2BLK93's Avatar
IMO have it scanned first and check for codes...take a look at the O2's and see what they are doing.
Old 08-15-2007, 01:51 PM
socal's Avatar
i swiched to the ltcc kit best move ever
http://www.geocities.com/reilym/LTCC/
http://www.bailey-eng.com/
http://www.delteq.com/products.htm
Old 08-15-2007, 02:17 PM
is the one from bailey a complete kit
Old 08-15-2007, 02:18 PM
plus i just wanna change the opti it has 141k on it and i dont think its been serviced
Old 08-15-2007, 02:50 PM
infinitebird's Avatar
No you have to buy the coils yourself and fab your own mounts.
If you want a complete kit go with the delteq.
Old 08-15-2007, 03:01 PM
LT1Falcon's Avatar
dont want to steal his thread or sound like a newb but what exactly is an ltcc kit? i did a search but didnt find much, is it like the coils on an LSX motor?
Old 08-15-2007, 03:15 PM
yes. socal posted the link above.
Old 08-15-2007, 03:53 PM
i would but i plan to make it above 6500rpm
Old 08-15-2007, 04:04 PM
Is there some reason the delteq will not work above 6500?
Old 08-15-2007, 04:27 PM
well dont on their site say "system is well-proven in its Northstar application with a stock redline of 6500 RPM"
Old 08-15-2007, 04:28 PM
whats better getting the bailey kit or the delteq?? or it depends on what u want
Old 08-15-2007, 04:43 PM
lol no. What that is saying is that the northstar engine had a stock redline of 6500 set, not that the delteq kit has that.
You will be just fine spinning much higher than 6500 with the delteq.
The delteq doesn't actually come with a separate rev limiter (unlike the LTCC) so your redline will be whatever the pcm has it set too.
Old 08-15-2007, 04:56 PM
lol ur shtting me lol well thats a bonus for that set well i think ima go with that one but whats the feedback on it
Old 08-15-2007, 07:39 PM
socal's Avatar
i like the ltcc kit, if i have a cylinder missing i can track it to that coil,wire,plug,connector,ect...
and it revs to 7k in my Ta, and has a built in retard for the nitrous so the car is tuned for regular driving but pulls the timing when on the spray
but the delteq is a complet kit and my 95 northstar made all it power in the higher RPM
so the choice is yours
Old 08-15-2007, 09:27 PM
blk97z28's Avatar
The deletq is a very very nice setup!! Yes you have fab your own mounts.
Quick Reply: ignition problem
