ls1 brake upgrade
Old 08-30-2007, 05:37 PM
1slowZinthe513's Avatar
Default ls1 brake upgrade
I'm in the process of upgrading to ls1 brakes.. the trouble I'm having right now is removing the spindle.. I don't have a puller.. All of the nuts are off and its just stuck right now on the middle lower bolt and its rusty.. I hit it with a **** load of WD40 and i have been whacking it with a hammer and it wont come off.. any suggestions?
Old 08-30-2007, 07:30 PM
infinitebird's Avatar
Unless you have a better tool to use you just have to pull really hard. It helps to yank on it in bursts rather than apply steady pressure. Also pull it while turning it. It took me a while to get mine off too, but I got eventually.
Old 08-30-2007, 08:00 PM
yanked the **** out of that thing.. damn near pulled my back out.. went into the garage and got the slug hammer.. took care of it in two swings
Old 08-30-2007, 08:24 PM
fast's Avatar
nvm, I was thinking of the wrong part
Old 08-30-2007, 08:29 PM
96lt1m6's Avatar
ball joint seperator,tunning fork etc.
i would get a small 2x4 hydr.jack place it under the spindle,put the castle nutt back on to cover the top(screw it on till the nutt is flush with the top of the joint and tap it a few times with a BFH (5lbsledge).do not mushroom the castle nutt!
Old 08-31-2007, 02:08 AM
Imnotfast's Avatar
Dont hit the balljoint. You hit the side of the spindle. Found the the jack cup will hold the rotor well to get 2 or 3 good hits and its off. Make sure the upper joint has a nut on it doe the spindle dont go flying out.
Old 08-31-2007, 02:21 AM
In-Zane Moderator
ZONES89RS's Avatar
X2
Old 08-31-2007, 02:31 AM
Imnotfast's Avatar
Originally Posted by ZONES89RS
X2
If you use this tool be VERY careful not to rip the boot.
Old 08-31-2007, 06:41 AM
solarofthesix's Avatar
its nto a hammer....its a calibrated whackometer....buddy of mine used a hydrolic dent puller/pusher
Old 08-31-2007, 07:09 AM
moehorsepower's Avatar
Default hammer
Yes this is the easiest way, I use a 5lb sledge hammer and hit the side of the spindle and it will break free, usually in a couple of strong Homerun hits will do. the ball joint seperater will probably tear the boot..
Quick Reply: ls1 brake upgrade
