power steering
Old 10-03-2007, 07:29 PM
cruzin94's Avatar
Default power steering
i replaced my power steering pump and i was wondering how do i bleed a power steering system any help would be appreciated mike
Old 10-03-2007, 07:32 PM
ThoR294's Avatar
just turn the wheel all the way to the left and all the way to the right... the fluid will have bubbles in it for a day or two. make sure its topped off and do not over fill!
Old 10-03-2007, 07:38 PM
AR15 guy's Avatar
I have changed pumps on 2 lt1's and never bled it. I don't think you can. Unless there is a way to bleed the rack. Just drive it and check the fluid for a couple days. When I changed my brothers pump it didn't feel like it was working at first. Then I guess the air released because it started working fine.
Old 10-03-2007, 08:01 PM
ThoR294's Avatar
yeah... cause you bled the system by turning the wheel all the way one way then all the way the other... then it worked
Old 10-03-2007, 08:14 PM
cruzin94's Avatar
thanks guys
Old 10-03-2007, 08:44 PM
dhdenney's Avatar
I have (with the belt off of course), filled the reservoir and turned the pulley by hand several times. Don't know if I did any good or not, but I like to think I did.
Old 10-03-2007, 08:49 PM
ThoR294's Avatar
haha. you bled the pump, but you didnt bleed the whole system
Old 10-03-2007, 09:07 PM
dhdenney's Avatar
Like we said, can't really bleed the rack.
Old 10-03-2007, 09:12 PM
ThoR294's Avatar
well. the best way is to just run the car and turn the wheel all the way
Quick Reply: power steering
