500rwhp
500rwhp
Hi all.
I build 396cid with 227AFR, CR 11:1. I can not pick up correct cam, your help is necessary. Intake Edelbrock LT4, it is possible on these completing to receive 500rwhp, what will be idling? What to apply size inlectors with stoke PCM.
Thanks
Thanks
You can NOT use a stock PCM. It WILL need a tune to accommodate all of that. Injector size will probably be in the 50# area if you're not using any power adders, that is, if it is natually aspirated (not turbo, supercharger, or NOS).
I don't think he will need that high of Injectors..Just comparing this for a sec..I have 34lb's on my current setup..I know it's LSX, but the Heads I have probably flow close to if not a little more than them AFR's he has up there..and I have big Cam, and the Injectors run at 90% Duty Cycle at WOT.
No doubt it will be a custom Cam and a good Tune..
you will need a good custom cam, atleast 1 7/8 long tubes, and a good tune. im lookin at building a 383 thats going to put out around 500rwhp. thats also a 6 speed though, and for the injectors just go with some 42s that should be more than enough and will give you room to play later on. talk to SSTROKERACE on the forum, he can hook you up with the right cam for that motor.
Yes, Therefore there is no opportunity to return problem details.
So help to pick up accessories correctly. Where it is better to order stroker kit.
