Fastest stock heads, no power adder times?
Old 12-15-2007, 04:20 PM
tylert14's Avatar
Default Fastest stock heads, no power adder times?
Hey guys, kinda weird request I guess, but I was just wondering what are some of the fastest N/A F bodys with stock heads. Anything else goes, except for N/A, stock heads, and stock PCM.
Old 12-15-2007, 04:41 PM
95 Formula's Avatar
I think Frank Benoit (Frank95Z) went 11.3s.
Old 12-15-2007, 04:59 PM
Davey J's Avatar
FASTEST CAM ONLY LT1
Frank95z
1995 Z28, stockheads ,A4,52TB, cold air,hooker longtube headers, Joe O custom grind cam, 1.6rr,Strange 12bolt,QT Pros, Vig3200, 3325lbs
1/4: 11.163 @ 119.86
1/8: 7.05 @ 96.00
1.49 60 ft
Old 12-15-2007, 05:09 PM
lt1taracing's Avatar
7.09@97/11.12@122 with my original heads and factory 1.94x1.50 valves all motor. i dont make very many motor passes it could possibly run a little faster.
Old 12-15-2007, 07:38 PM
Razor_Blade's Avatar
Stock Eliminator cars run well into the 10's on non ported factory heads and intake manifolds. I'm not positive, but pretty sure that they use a stock throttle body as well.
Old 12-15-2007, 08:05 PM
Davey J's Avatar
The LT1 heads are a big bottleneck for sure.Are they doing this on a 23 degree head?
Old 12-15-2007, 08:17 PM
z28hustle's Avatar
i wish people would say what it is exactly that they are doing to these lil stock eliminator monsters to get them to go so fuggin fast...
Old 12-15-2007, 08:23 PM
fergymoto's Avatar
I don't know why people say the LT1 heads are such a big bottleneck. Compared to worked LT1 heads by places like LE, AI, Port Pros, etc, or compared to LS1 heads maybe. But for a stock 23 degree small block cylinder head they flow really well.
Old 12-15-2007, 08:32 PM
Davey J's Avatar
The stock unported LT1 head does flow good in a 12 second car but I bet if I took off my afr heads and replaced them with untouched LT1 heads my mid 10 second car would be a mid 11 second car if that
Old 12-15-2007, 09:07 PM
Yes, they are limited to the factory LT1 heads and intake manifold with absolutely no port work whatsoever. I'm not sure about the valves and valve job though.
Old 12-15-2007, 09:16 PM
TAEnvy's Avatar
Ive talked to a head porter and they say the pro stock heads are no were near stock, they are just made to LOOK stock.
Old 12-15-2007, 09:20 PM
You may be right, but in my book a mid 11 second car with untouched 23 degree heads is simply amazing. The LT1 head is leaps and bounds ahead of the old late seventies and early eighties smogger heads that many of us had to deal with.
Old 12-15-2007, 09:21 PM
daniel6718's Avatar
yes im sure some1 has run low 10's to mid 9's with stock heads before....might even be 8's if they were doing it in a lighweight car like a grimlin or old school rx7.....
a stock motor cam only with a solid roller im pretty sure is capable of 400 rwhp
Old 12-15-2007, 09:29 PM
I've never talked to a knowledgable head porter on the subject, but I do know that the Stock Eliminator Cars are subject to tear down and inspection, where the ports would be measured and need to be within a certain tolerance. I'm sure there has been cheating involved, but it's hard to believe that everone could get away with it.
BTW, I just noticed that you mentioned Pro Stock. If I'm not mistaken that's a totaly different animal.
Old 12-15-2007, 09:31 PM
matt94z's Avatar
Stock eliminator cars can't have any port work done and must use cams with stock lift. It is a totally different class than pro stock....
Old 12-15-2007, 09:45 PM
Davey J's Avatar
I dont know how they can do it maybe they weigh like 2800 lbs
I know they 60ft in the 1.3`s
Old 12-15-2007, 09:53 PM
stock elim. cars must run stock sized valves but can run back cut aftermarket valves with 3 angle valve job. the lift of the cam is stock but the duration can be whatever. i've heard of people sucking sand through a port under hi psi. to increase port volume without it looking ported. they are also limited to a 51.9cc combustion chamber. these cars are subject to tear down but, i wouldnt think it happens as much anymore, since they run on a dile in. the nat. index seems to be just for bragging rights. they do run stock t/b's (48mm). in 04 tim bishop held the record in b/fi stock at 10.29 @129.8 mph. weighing in at 3140 w/d. in a 97 formula. it put 449hp to the wheels. they record has probably been reset since then. this is my favorite class in all of drag racing. these cars are "trick" all over.
Old 12-15-2007, 09:58 PM
The cars are pretty light, but they use ballast which puts the weight back in the most advantages part of the car. I think the exact weight depends on what horse power the car is running, I've read that the LT1 F-Bodies race at around 3200 pounds. The entire car is meticulously blue printed.
Old 12-15-2007, 10:06 PM
BTW, in no way of my statement of sucking sand through ports , am i claiming anyone that i know of has done this to my knowledge. this was just something i had heard from yrs. ago. (1980s). afew other cool facts about stock elim. is they must run on 9" slicks max. factory cranks although they can be offset ground, a max. of .060 overbore, stock type rods, and stock type pistons(can be forged, but in an lt1s case must remain flat top). they are also allowed aftermarket dfi. such as f.a.s.t. . the car i mentioned early leaves at 6200 and runs a jericho fourspeed. best 60ft. was 1.42.
Old 12-16-2007, 09:39 PM
96lt1m6's Avatar
Super Stock also use a BUNCH OF GEAR
4.88
5.13
5.86
6.14
Quick Reply: Fastest stock heads, no power adder times?
