cam only dyno # inside
just got back from the dyno.
386.6hp @5600? I think the rpm wasnt calibrated right.
420.8tq? @3782?
hp + tq met at 4800rpm
on a mustang dyno running dynojet software, through slp2otl
max power was at 129mph... max tq @ 90mph
with mustang software and cutout open.
345.7 @6000
342.7 @4171
hp + tq met at 4000rpm
mods in sig.
420.8tq? @3782?
345.7 @6000
342.7 @4171
mods in sig.
Calling a 355 cam only is a bit misleading. A properly done shortblock is worth some power.
HP and torque can not meet at 4800 rpm so there was a problem with the setup or software. torque multiplied by RPM divided by 5250 equals hp so the 4800 is a problem with the setup.
ya its a little ole 355. heads are unported intake unported, stock throttle body
where should the hp and tq meet? I know the rpm cal was off cause I know the max hp should be around 6100-6200
corrected # are 375hp and 408tq
and I did beat a cam only ls1 that dyno'd 389hp. by about 1-2 cars so I know this is a big torque motor.
what cc wre the pistons? whis will tell us weather or not they were worth and tq...it shouldent change power at all...which is a little high...id believe 365-370 not any more
definately not with a stock t/b injectors no pullies
shorties or longtubes? what kind of intake?
car has injectors, pullies, with longtubes, custom 3"y and 3in Y back. bone stock lt1 intake manifold. heads have valve job and lt4 valves
dont have info on pistons
thats some good *** numbers.. not sure how you got them.. what kind of cam are you running? im running about the same setup.. 355.. bolt ons and LT4 hotcam and i only made like 330whp and 367wtq..
unknown specs on cam, just know that its a custom lme shaft. sotp car quits pulling right at 6200 I spin it to about 6500
both pulls had a hickup at about 4900 hp fell off about 2-3hp for about 25-30rpm then picked back up. torque fell off a little more.
