MSD box on a stock opti?
Old 04-09-2008, 07:09 AM
travailrx7's Avatar
Question MSD box on a stock opti?
Can you run a MSD ignition box on a stock opti and will the MSD ignition box's fry the stock opit.
Old 04-09-2008, 07:19 AM
Vicious95Z28's Avatar
That's what I hear. It seems that the stock opti cap/rotor tend to frown upon the MSD OUTPUT.
Old 04-09-2008, 07:53 AM
travailrx7's Avatar
I have a MSD cap and rotor and a MSD coil on the car.
Old 04-09-2008, 08:44 AM
imnotplutonium's Avatar
i have a full msd system on my car, minus the opti that is stock. BUT, it is not the original. the msd system destroyed my original opti and I had to get it replaced. I can't prove it was the msd but very shortly after the install it crapped out.
i had a friend of my dad's work on it and he tried blaming the msd system and replaced all of it with stock ignition parts and it ran worse. turns out it was the opti like I told him in the first place.
long story short on a low mileage opti i would not worry
Old 04-09-2008, 10:18 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
My 94 still has the OEM/STOCK opti on the car, and has been running a MSD Digital 6 and a big MSD coil for over 6 years.
I have had absolutley zero opti related issues, maybe mine is a freak.
Old 04-09-2008, 04:55 PM
grn95t/a's Avatar
ran my stock opti on a 6al for a few thousand miles before i did the cam install and changed to the msd cap and rotor. the stock pieces looked good when i pulled them other than only one plastic rivet left and loose. lol!
Old 04-09-2008, 05:07 PM
LT1capriceclassic's Avatar
I just put a 6al in my 94 caprice w/ the stock opti and it took the opti out in about 600 miles. But the car does have 136k so still not sure if the msd just did it in or just having that many miles did.
Old 04-09-2008, 05:09 PM
Geneticallybroke's Avatar
I installed the 6al box on my T/A with 1yr old opti and it only lasted two weeks. Maybe it was a defective opti???
Old 04-09-2008, 05:29 PM
96capricemgr's Avatar
You know when folks ask a question like this I think the first response should be someone asking you why you want to put a box on the car atall???
The stock ignition really doesn't need any help until the car is pretty substantially modded. There are features that can come in handy when doing certain mods but if you are thinking of "improving the spark for efficiency" or the like then you are wrong and about to waste money.
Old 04-09-2008, 06:10 PM
1redta's Avatar
Default re
This is true, but I did to my car because; the MSD 6/digital 6 are relatively cheap, I learned some things about the ignition system of my car ( replaced wires plugs) and I enjoy modding my car Art
Old 04-09-2008, 09:03 PM
travailrx7's Avatar
The motor has been modd with a 306 com cam.1.6rocker.58mmTB,intake.headers,push rods.cc value springs.full MSD set up,ported stock heads,3in MAS,LT4 SCM.so my motor is not stock.This is why I ask if I can run a ignition box on a stock opit.
Old 04-09-2008, 09:10 PM
ineedanls1's Avatar
i have a 6al and stock opti but installed them both at the same time...working fine been about 13k...its just one of those things knock and wood and go for it...
Old 04-09-2008, 09:51 PM
95hawk467's Avatar
I have a gm replacement opti and Msd dif6 box and blaster coil with no ill effects.
Old 04-09-2008, 11:00 PM
95zpro's Avatar
haven't had a problem with my setup; msd 6al, blaster coil & msd wires and I haven't had a problem !
Old 04-09-2008, 11:19 PM
ineedanls1's Avatar
i think i heard somewhere that the blaster coil ***** up the opti i just have the 6al no problems..
Old 04-10-2008, 09:26 AM
Z-RATED94's Avatar
Same here, 6A box and upgraded coil for years. I switched to the 685 box only because I added nitrous and needed more features. MSD 6A is for sale if your interested.
Old 04-10-2008, 10:22 AM
Moderator
BizZzatch350's Avatar
Have yet to see any concrete evidence that an ignition box destroys the opti.
Old 04-10-2008, 10:29 AM
speed_demon24's Avatar
Every stock cap that I have personally seen showed signs of arcing when it was run with an ignition box. I don't know if it would have still showed the signs of arcing without an ignition box but I thought i'de just throw that out there.
Old 04-10-2008, 11:16 AM
yea stock ignition is fine but I was young and it was affordable. it will help later on with a FI setup..... a lot later on. lol
Quick Reply: MSD box on a stock opti?
