my first lt1 need advice,on the cars
i just sold my forged 96 cobra,i thought i would try a 95 z28,but it needs rebuilt,so im getting everything from summit in a kit,ive heard several problems with these cars,the opti spark for one.so what is the most common of things that go down on these cars besides this.and i need a good part# for the mellin oil pump.1 # i found was 10554,is this right,i read in here that the hv was not good for this car.any advice will help.
yep my rear main seal, oil pan gasket, and about everywhere holding oil seems to leak just a little, but i only have to add about a half a quart between changes... but i just did an opti swap and it wasn't fun... just a word to the wise, make sure and mark on the block, spline, and back of the opti all of where the shaft goes because if not, you are pretty well screwed because that shaft feels like it can go in any way, although it only really does go in one way... so be careful on that... also, make sure the oil pressure is good because i have heard of tons of oil pressure problems, like where the pressure surges at WOT and just does crazy stuff like that...but other than the known problems, they seem to be good cars
1 Post
i dont know... a forged 24-valve still sounds superior to me... it can handle quite a bit of stress and boost, if needed, too. the LT1 is a great motor; don't get me wrong. but, it just still seems a little outdated compared to a modular, forged, DOHC motor... now, an LS1, on the other hand, is a different story...
