lake wood traction bars
do any of you guys use these or are they a waste over the lca and relocate brackets?? would they be good for a bolt on car or is it just way to much? if they do work it like they say it sounds like it would be worth it.
http://www.sfxperformance.com/parts/LAK21700.htm
thanks
thanks
hashtagBMW
That doesnt look to be that great of a unit either.
Check out these..
http://www.umiperformance.com/2018 - On car adjustabilty and a poly end.
http://www.umiperformance.com/2010 - Relocation brackets.
UMI stuff is top notch, its what I run on my car and plan to go low 9's
Tony.
Check out these..
Tony.
thanks guys i was defiently going to get low control arms and then ran across them. i defiently need something to help it hook better. the stock suspension and the bfgs arent cutting it after the converter.
Hello,
Like Tony mentioned above I highly recommend a set of control arms and relocation brackets over that set-up.
We have control arms starting at $109.99 a set and bolt in relocation brackets at $89.95 making a entire kit only $199.94
If you have any questions please ask and I am glad to help.
Thank you!
Ryan
Thank you!
Ryan
