Opinion on which 1.6 RR
Old 07-02-2008, 06:43 PM
alabamapimpin's Avatar
Default Opinion on which 1.6 RR
just wanting to hear opinions on which 1.6RR to go with i will have AI 200cc heads soon with 7/16 studs thanx
Old 07-02-2008, 07:11 PM
StealthFormula's Avatar
Without doubt no questions asked Comp Cams Pro-Mag NSA 1.6's. 1305-16. If you asked Ai they would tell you the same.
Old 07-02-2008, 07:52 PM
96lt1m6's Avatar
personally i feel the comp promags are the best out there,construction and durability win hands down! great to see someone using 7/16 studs in their build
next would be a set of shaft mounts....
Old 07-02-2008, 08:24 PM
mightyquickz28's Avatar
Yep. Comp Cams 7/16" stud 1.6 ratio ProMags. I'm not sure if they even come as SA (Self Aligning). If they're only non-SA( Mine are) you'll need the CORRECT guideplates and hardened pushrods for those heads.
Old 07-02-2008, 08:58 PM
i was thinking about the roller kit AI has for $725 and thanx for all the replies it has the cc pro mags once again thanx alot guys
Old 07-03-2008, 10:27 AM
Captainofiron's Avatar
I got some steel 1.65 full roller rockers, and I love them, the noise annoys me sometimes, but IMO dont go with aluminum rockers, especially the cranes
Old 07-03-2008, 10:41 AM
LTBANDIT's Avatar
SEVEN TWENTY FIVE!??? ef that, get Comp pro mags like previously stated and be done...
Old 07-03-2008, 10:45 AM
James Montigny's Avatar
ProMags have always done me well.
Although I've also had good luck with Crane.
Old 07-03-2008, 12:38 PM
1989GTA's Avatar
A contrary opinion. I'm currently building up a new motor for my car and the question of rockers arms and valve train has come up. I plan on turning my motor to the 7000rpm mark.
I told a couple of big name in the industry of my plans as I'm buying parts off of them and getting some free advice. I currently have the 1.6 Comp Pro Magnums. The consenus was the Pro Magnums were not the way to go as they are to heavy for a higher rpm opertion. I would be better off with any of the aluminum rocker arms.
One of the builders has tested most of the rocker arms available and says that the Harland Sharp rocker arms are a little higher rated and quite a few are under what they are rated. He thinks Harland Sharp does that to compensate for valve train flex. So Harland Sharp for me.
Edit: I was also told that in the last year Comp has quietly come out with a high grade aluminum rocker arm.
Old 07-03-2008, 01:41 PM
Roadwarrior1956's Avatar
You kidding me! my engine rev's too 6500 rpm so easily with 1.6 Comp Pro Magnums rockers it still amazes me, they should no problem going too 7000
Old 07-03-2008, 03:41 PM
1989GTA's Avatar
No kidding around. Above 6500rpm how do you know you are not getting valve float. You may not be able to hear it.
Anyways it is just another opinion and everyone can take it for what it is worth and go on their merry way.
