LT1 M6 Bolt-on guys with 4.11s come on in...
& tell me what your ETs are, Now this is with STOCK cammed cars, just your basic bolt-ons, please list your 60fts, altitude & ETs with either a street tire or stickies, just trying to get a baseline on what i might run.
I did pull off a 13.7 on a 2.17 with 3.42s, i'm hopeing with the 4.11s & 1.8s or better 60fts, i should be there, that would be cool
Keep them coming.
that would be great if i could see a 12.99, then again i wouldn't see why it wouldn't do it in the cooler months, i 'm also installing a good driveshaft for added insurance for sticky tires.
Keep them coming.
Keep them coming.
Larger diameter cat-back, with straight-thru muffler(bullet style)
12bolt with 3.73 gears
26" slicks
That is the ONLY changes between those times and my best of the day, 13.09. Consistent 13.1's with the stock clutch. The clutch did NOT last all day tho'.
I ran a 12.61 @ 109 with 26" ET street (Moser 12 bolt 4:11's) with pretty much every bolt-on you can do except, (NO PCM tune and NO cut-out). The car is a full weight WS6 LT1 with all factory options (I'm guessing the car weighed in the 3550 range when I ran that number). Since then, I have added ED Wright PCM tune and a bunch of suspension items. I'm sure the car has a 12.30/40 ish in it @ 110 plus.
Branson, i'll be at Ozark Dragway this friday night to test it out, just got the 3rd. member & axles in, everythings nice & tight now, i'll pick up my driveshaft tomorrow.
I'm at 1500ft. alt. with high humitity, i'll be lucky if i get 102 out of it (in good air), unless the 4.11s give it more MPH then the 3.42s, the only F bodies running faster then 106 (in stockish trim) around here are the LS1 cars, i know of a 95 bolt-on A4 running 13 teens, but his MPH is only 102-103 at best.
