Need header / exhaust advise
Old 09-08-2008, 06:24 PM
AKAKWIK's Avatar
Default Need header / exhaust advise
I have the LT1 out of my 97 SS and want to upgrade the exhaust while it is out. It has the SLP dual dual catback, and I want to keep the cats on. I was considering BBK shorties, but is there a economical (< $1000) way to run long tubes and cats? Thanks for any advise.
Old 09-08-2008, 06:26 PM
Fixxer99TA's Avatar
You could potentially keep the cost of LTs/Catted Y/Catback under the cost of 1k if you play your cards right (Just buy the LTs, 2 cats, and a catback and have it welded up). Doing the install yourself on the LTs will be a huge part of it. Shorties arent really worth the price, you would be better off trying to make a setup with LTs or Mids or just not doing it at all.
Old 09-08-2008, 07:44 PM
AKAKWIK's Avatar
Default headers and two cats
Thanks for the quick response. Are there any kits out there that will install headers and 2 cats and I can tie into my existing catback? I don't know where 2 cat can go with anything other than shorties.
Old 09-08-2008, 07:49 PM
Camaro_94's Avatar
Why is it that you want to keep the cats on there?
Just wondering.
- Mike
Old 09-08-2008, 07:54 PM
AKAKWIK's Avatar
VA has annual inspections...they don't sniff where I live but they should do a visual inspection. Just wanted to avoid the hassles.
Old 09-08-2008, 07:58 PM
ryan00z28camaro's Avatar
i say do lt with cats and a muffler shop to do the fab
Old 09-09-2008, 07:27 PM
AKAKWIK's Avatar
Has anyone installed the Pacesetter mid-tubes on a 96-97 Camaro? And what kind of gain will mid-tubes give?
Old 09-09-2008, 07:51 PM
Formula350's Avatar
If it's visual only, hollow out the cats and run a pipe through it. Or cut the cat in half (length wise) and weld it over a pipe so you can use which ever size ID you want.
If they're REALLY **** about visuals, then they're going to cite you for them being in the wrong place.
Old 09-09-2008, 08:37 PM
SoxXpupPeT's Avatar
mac mids will put the Y pipe in the stock location for the cat. itll require alittle modifying but its all good
Old 09-09-2008, 09:25 PM
AChotrod's Avatar
how about Lpp LTs and a Kooks catted y-pipe? If you do the install yourself should be in the right price range. You might have to modify the y-pipe though.? Just a thought.
Oh and I had JBA shorties on my ol 97. Worked great with stock cats and y-pipe you just need to weld on an extension to the stock y.
Quick Reply: Need header / exhaust advise
