need help locating a part
Old 10-01-2008, 01:00 AM
bad99transam's Avatar
Default need help locating a part
i just bought a lt4 know modual and i was woundering were it is located at on the car.
Old 10-01-2008, 06:32 AM
FlamingChicken's Avatar
im assuming you meant knock module and i believe its inside the pcm. open her up and switch them out. try to verify that before you start but im pretty sure about that one.
Old 10-01-2008, 04:00 PM
EAO SHOT's Avatar
It's not near the PCM. I have a 1994 Firehawk and just changed mine out. Mine was located in engine bay, right side inner fender near the firewall.
Old 10-01-2008, 04:10 PM
Goat2NV's Avatar
Pop your hood, go to the passenger side, and right between the firewall and the fender, the computer will sit. Unbolt it from the fender, its a 10mm bolt, then gently pull up the computer, flip it over and there will be a cover, held in place by 2 bolts. Those bolts are T20s, unbolt them, remove the cover and you will find your knock module. Hope this helps. Also make sure that you disconnect your batter before you start.
Old 10-01-2008, 05:46 PM
WH97Z's Avatar
I second that last post!
Old 10-01-2008, 05:47 PM
NicksTAgt's Avatar
tr00f
Old 10-03-2008, 03:29 PM
thanks for the info
Old 10-03-2008, 04:50 PM
LT1
LT1's Avatar
i hope this link helps you
http://www.97ta.com/LT4_knock_module.shtml
Quick Reply: need help locating a part
