Change rear main seal while clutch is out?
Old 11-02-2003, 05:17 PM
Smartass6885's Avatar
Default Change rear main seal while clutch is out?
I talked to a guy about installing my new clutch, and he mentioned maybe replacing the rear main seal. I have never heard of anyone bothering to do so unless it is leaking or somthing. Anyone ever have a problem with a leaky rear main seal? And just curious if there is anything else i will need or you suggest i get during my clutch install. Heres what i already ordered.
Star Spec Stage II clutch.
Updated GM hydraulics.
GM high carbon billet flywheel.
New pilot bearing.
Any suggestions would be appreciated.
Thanks
Old 11-03-2003, 06:11 PM
Anyone?
Old 11-03-2003, 06:18 PM
ss rally red's Avatar
I know it is common place to replace rear main seals on a lot of cars when the trans is coming out anyway, you are right there at it and most of the time shops don't charge any extra labor if it is a simple swap. I dont know if the LS1 has a one or two piece seal but if your car has some miles and it is a simple replacement it wouldn't hurt.
Old 11-04-2003, 10:41 AM
SixSpeed's Avatar
Sound like a good idea to me...Does anyone know the part numbers of what would be needed? Something else for my gmpartsdirect.com list! he he he
Thanks!
Old 11-04-2003, 03:10 PM
Scalpel's Avatar
Check for the part # on ls1howto.com
Old 11-04-2003, 07:20 PM
Thanks for your response guys, I will order one tomorrow beore i start my install. I will post back up with how much it cost me and how hard it was to install. Talk to u later.
Old 11-04-2003, 08:38 PM
AINT SKEERED's Avatar
My rear seal has been changed 3 times and I still have a leak. If it aint leakin dont touch it. JMO
Old 11-07-2003, 09:39 PM
Well it would have took too long for the seal to get here. So i didnt change it. I guess i am kinda glad since AINT SKEERED is leaking after being changed. Thanks for your response.
Quick Reply: Change rear main seal while clutch is out?
