Need help!!! T-56 output shaft seal leaking still
Old 07-02-2009, 02:55 PM
2002nbmssdd's Avatar
Default Need help!!! T-56 output shaft seal leaking still
I need someone to please tell me where else the fluid could be leaking from. I replaced the tailshaft seal with an OEM from the dealership. I checked for cracks in the tailshaft and could'nt see any. The trans fluid is still dripping slightly from around the bottom of this seal that I replaced. I am so frustrated and don't know what to do. Any suggestions would be greatly appreciated.
Old 07-02-2009, 02:56 PM
thesource's Avatar
It probably needs a new tailhousing bushing as well.
Old 07-02-2009, 03:01 PM
do you have a gm part number for that bushing and is it hard to replace? Thanks for responding so quickly
Old 08-09-2009, 07:34 PM
martinls1's Avatar
did you ever get it to stop leaking?
Old 09-30-2009, 11:58 PM
dutinsss's Avatar
i'm having the same problem, so i got the seal and bushing. i can't imagine the seal being hard to replace, but what do i need to replace the bushing?
Old 10-01-2009, 07:56 PM
martinls1's Avatar
I replaced mine by taking off the tailshaft extension housing and took it to a shop to press in the new bushing. Easy.....
Old 10-01-2009, 09:47 PM
dutinsss's Avatar
so all you have to do is take the tailshaft off and the bushing and seal will be in that assembly?
Old 10-01-2009, 10:37 PM
martinls1's Avatar
Red face
Correct.......you can replace the seal without taking the housing off, but to replace the bushing, you take the housing off and the bushing is in the housing.
Old 10-01-2009, 11:58 PM
dutinsss's Avatar
ok, thanks a lot. just wanted to make sure it was that simple before i started taking things apart.
Old 10-02-2009, 03:07 PM
jmd
jmd's Avatar
The tool to do the bushing w/out disassembling the transmission is very helpful. But, if you can get the tail off and the bushing presses in without issue, go without the tool.
Old 10-02-2009, 11:13 PM
dutinsss's Avatar
the tail shaft just unbolts from the end of the trans on these cars right? why would i have to disassemble the trans? i was under the impression you could just take the tail shaft off with the trans in the car unless i'm missing something.
Old 10-03-2009, 04:31 AM
jmd
jmd's Avatar
I'll restate that.
The tool to do the bushing without removing the tailhousing from the transmission is very helpful. But, if you wish to take the tailhousing off and yours takes a pressed-in bushing without issue, that's cool.
Old 10-03-2009, 09:39 AM
dutinsss's Avatar
oh ok, that makes sense now. thanks again for the help guys.
Quick Reply: Need help!!! T-56 output shaft seal leaking still
