pump to fill trans?
Old 07-09-2009, 01:14 AM
pHEnomIC's Avatar
Default pump to fill trans?
Where can i get a cheap pump to fill the transmission? I had couple of pos general purpose fluid pumps but they were ineffective.
Old 07-09-2009, 06:54 AM
jeepers_88's Avatar
I work in a shop and we dont have a fluid pump for everyone to use, so I went to home depot one day and picked up a bug sprayer. It says "RL Flowmaster" on the side. It was about $12 and works great for filling trannys. Im the only one that has one so everyone in the shop uses it, its filled about 50 trannys or so and is still kicking, its a little slow but works really well. Just make sure you get the one with the metal nozzle thats about a foot long so you can bend the end of it to go into the trans fill hole.
Old 07-09-2009, 07:09 AM
puggerton03's Avatar
cut the tip and force the bottle up there and squeeze it till it goes in. if you do it right you wont spill much.
Old 07-09-2009, 08:06 AM
the_merv's Avatar
What about un-bolting the Shifter and dumping the 4 Quarts in there?
Old 07-09-2009, 08:56 AM
jmm98LS1's Avatar
^^^That's how I usually do it.
Old 07-09-2009, 09:51 AM
pHEnomIC's Avatar
Too much work lol
Old 07-09-2009, 10:53 AM
the_merv's Avatar
Originally Posted by pHEnomIC
Too much work lol
Weak..
Old 07-09-2009, 06:26 PM
NVR_SPDS's Avatar
I just bought one of those cheap hand pumps that screw in to the top of the bottles. Worked for Royal purple gear oil in the diff, and ATF in our built trans with no issues at all.
Old 07-10-2009, 12:22 AM
SlideRight's Avatar
If your working on a manual transmission you can go through the tail housing. Remove the shifter boot and thift stick thing and put a drain pan under the fill plug so when its full the overflow will go into it. Worked for me *shrug*
Old 07-10-2009, 04:13 AM
johnnybravo's Avatar
I got one at Auto Zone. 10 or 12 bucks. it served it's purpose. It was a bit slow, but then I wasn't in a hurry.
Glad I did it, the tranny shifts easier now.
Old 07-10-2009, 05:43 AM
ghettocruiser's Avatar
I use this from autozone. Like $10. Pumps out a quart pretty quick. Good use for other things too.
I either do it that way, or pop the shifter. Its a couple screws, a boot, 4 bolts and alittle rtv...
J.
Old 07-10-2009, 05:51 AM
Chief Z's Avatar
I use a long flexible straw from my kid's sports bottle. Snaps right onto the fluid bottle tip. Just squeeze. It's free and it works. Never needed a pump. But then, I don't have a shop either.
Old 07-10-2009, 05:59 AM
sujomatt's Avatar
Oil scavenge pump... just plug it up to a spare battery
Old 07-10-2009, 11:42 AM
SlideRight's Avatar
i like the straw idea, i might have to give it a shot
Old 07-10-2009, 06:08 PM
mikeagentorangeeornt's Avatar
I use a piece of 3/8 fuel line and it works great. Push it on the tip of the bottle and squeeze away.
Quick Reply: pump to fill trans?
